What do i need to look at first
Look for a crack in the block or head, a blown gasket, or a bad expansion plug*. I assume the water is your coolant. If that is the case, the level in the radiator will be low.
The coolant leak could be up higher - perhaps it's coming from the thermostat plumbing or the temperature sensor. It could even be a crack in one of the heater hoses. The worst case is the cracked block - in that case the engine is essentially junk. A leaky hose connection is the easiest to fix.
*Note on expansion plugs (AKA freeze plugs). These look like inverted jar lids pressed into the block and are designed to be pushed out if the coolant freezes so the expansion of the ice doesn't crack the block (freezing can happen if you don't have a proper anti-freeze/water mix in cold weather). If you don't replace your anti-freeze according to the maintenance schedule, they may rust out and cause a leak.
