Maybe charger took a surge and fried it
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
SOURCE: Jet 3 Ultra won't charge
Indeed, you need to find a repair shop. Try a google search for power chair repair, or ask your local hospital or if you can find one a power chair store. Most likely, you have a mechanical failure of the wiring, the battery themselves, or corrosion on the battery posts. Since the chair lights up when the charger is in, it is unlikely that the charger is broken. You may have a failure of the controller board, but that is also unlikely. And batteries do not usually suddenly fail completely; they typically fail slowly, losing the ability to completely charge.
I assume that you did not see a great deal of fluid leaking out of the battery container; you might look in the container and check to see if a battery is cracked or missing fluid.
SOURCE: The charge lights blink and the chair won,t go.
Just had this problem with my Guardian Aspire. They had to replace the electronic box with the joy stick. BIG BUCKS!
SOURCE: All six lights blink on my Jet 3
I just had the same problem with my uncle's power chair. The number of "blinks" indicates a problem code to the technicians. My chair needed the joystick control assembly replaced. Once replaced, evrything was back to normal. 'Not a cheap fix but much needed. Good luck my friend!!
SOURCE: red light on my jet 7 keeps blinking and chair barely moves.
Sound like the batteries are on their last leg. Have them load tested.
SOURCE: When I plug in my jet 3 ultra the ammeter reads 0.
Its showing you the voltage out put for the charger if all power lights are lit and the chager is pluged in if batteries show only 2vlts then they are no good and the will not charge up thats why amp meter is on 0
