The F35 error code indicates an analog pressure sensor error. The
analog pressure sensor is the component that detects water level in the
washer tub.
This error can usually be cleared but it will occur again
if the main control board still detects a problem with the signal from
the analog pressure sensor. This error code can be caused by a problem
with the air pressure tube between the bottom of the washer tub and the
analog pressure sensor. If you are able to unplug the washer and
check this air pressure tube, you may be able to resolve this problem.
The analog pressure sensor can be accessed by pulling off the top panel
of your washer. Remove the screws at the very back of the top panel
and then pull it back slightly and then up and off of the washer. The
analog pressure sensor is "key 38" in the image below. With the
washer unplugged, check the connection of the air pressure tube to this
component. Check the entire air tube down to its connection to the
bottom of the washer tub. You will likely need to remove the back panel
of the washer to check the entire air pressure tube. If you find a
kink, tear, hose or loose connection in the air pressure tube, then this
is the likely cause of your F35 error code. If the air pressure tube
appears to be okay, then you will likely need to replace the analog
pressure sensor. If the problem still exists after replacing this
component, then the main electronic control board for the washer will
need to be replaced.
If you are not completely confident in your
technical ability to safely access and check these components, I
recommend calling a service technician to diagnose and repair the
washer. This information was based on the general description of the washer model that you provided (Kenmore Elite front load washer).
Hope this helps and just keep in mind that your feedback is important
and I'll appreciate your time and consideration if you leave some
testimonial comment about this answer. Thank you for using FixYa.
Jose.
