Hello Toshiba 28W93B 2563DB 536 063 271 098 117 232 530 581 130 473 088 182 064 216 253 508 Toshiba 156T9B 175T9B 213T4B 2151TB 2197DB 2512DB 2535DB 2539DB 2550TB 2563DB 256T9B 28Z27B2 2812DB 2857DB 2835DB 2873DB 2877DB 28W93B 2500TB 3357DB 573DB 2879DB T1510T8 25001TB7 32DB 32M8DB 2855DB CT9689 2939DB 40PW03B MV40PWA 32M9DB3 2893DB 32317B 2573DB 337BB 2552D 36/21P 28207B 2173DB 285T8B 2173DB 28W8DBA 28N03B 2505 238DB 439J936 3377DB 2181TB 82Z27B 28W23B 32ZP18P 42PW33P 32NW2DB 28ZH37B 32W8DB 32ZP38B 32NW7DB 32WIS 28N33B VTV1400 2987DB 536 Toshiba 2101TB 213T4B 2573DB 32ZP38 581 Toshiba 3377DB 216 Toshiba 2987DB 253 Toshiba 2987DB 3339DB 2877DB 322D09B 2173D6 14N21B2 14N21B2 063 Toshiba 14T01B, 21TO1B, CT815, CT81500082B, CT824, CT832 746 Toshiba TVD213B 726 Toshiba CT90040 508
Sky remote codes for Toshiba TVs are:
OK.
Sky+ Remote Control Unit Programming Procedure Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
?? If this works try the other TV functions.
?? If these work then the correct code has been selected.
?? It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press “TV” followed by the “Stand-by” button. Then to change channel on your Sky+ you would need to press the “Sky” button followed by the “TV guide” button.
