Ye people the code is 0206 . its not listed on sky inteactive .
The Sky box itself has instructions and model-specific codes:
Press Interactive > Sky Customer Service > Your Sky Remote.
All this info and how to program the remotes can now be found ON the sky system via interactive, 5, 5.
Sky Digibox Remote Control Codes
This page contains all known codes for TV sets. Sky television codes. It includes setting-up procedures for early remotes, later remotes and Sky-plus remotes. The codes also apply to the Open keyboard .
The
original Digibox remote might be programmed to control your TV set,
provided that your TV was built before 1999. Later revisions (see label
inside battery compartment) include later TV model codes but drop some
very early ones. Sky collects new codes from TV manufacturers and
stores them in its database. Every couple of years, Sky gives these
codes to the remote manufacturer and a new revision remote will appear
on the market. The remote includes BASIC functions such as up/down,
volume and number keys. it *might* also include special functions such
as text, but don't count on it. See accessories Catalogue for Digibox remotes.
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings below (Use the 4 digit codes from the left hand column), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes below or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code.
If you are still unable to control your TV from the remote control see: Programming The Sky Remote or go to Sky's official website where you can see if a particular remote control version number will operate your make of TV, this can be found at: Sky please remember to use your back button.
Akura 0042 246, 292, 397, 065, 440
CHECKED ALDREADY ON THE SKY INTERACTIVE BUT IT DOES NOT HAVEMY MODEL NUMBER ON THERE. I HAVE TRIED THE CODES FOR SIMILAR SIZE MODELS BUT THE CODE DOES NOT WORK ANY OTHER IDEAS PLEASE
