I got this piece as a seconds. There is no dial tone.. The base station does say that it is getting charged. I waited for 24 hours.. The battery is not warm either and no dial tone..
Is the battery dead or the touchpads not connecting to the circuit??
please help.
Thanks,
Yogesh
SOURCE: Handset No Link To Base error and no dial tone
I have the problem. I think it is because the battery i have in it was a Ni-MH and it should be a Ni-Cd. I am now looking for the right baterry Good luck Frank [email protected]
SOURCE: Handset ?No Link To Base? error and no dial tone
2/29 Have you registered or re-registered the handset?
"No link" can mean handset is not accepting radio wave of base unit. At Mfgr website pull-down operator's manual and look for registration instructions. Some sequence of buttons will create a radio signal from base (have handset off base) then another sequence of buttons on handset will accept radio signal. If handset has "menu" button, try "menu", then "00" (zero zero) then select an accept or "OK" button. Good luck.
SOURCE: GE cordless 900 mHz
Wow, This took quite some digging around to find, but here it is all 104 pages of the manual.
Follow this link:
http://157.254.235.130/public/15721090_R2.pdf
Hope this helps
SOURCE: searching is displayed on handset
Turn base around and find the area which says pager/registration. Push this button after you set internally the handset registration.
Menu/H set settings/Reg. Handset
