Cars & Trucks Logo
Posted on Aug 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi iam having an electrical problem after jump starting car at first i put the jump cables wrong way round !! then corrected error started car ok but had a fuse burn smell ! sho checked everything and found car roof light not working along with strereo and central locking & alarm! checked all fuses and found that the 15a power conn & R/LP FUSE had blown replaced & when turn on ignittion fuse blows straight away!!! do you any ideas! thanks rodger
Anonymous
Level 2:
  • Expert 147 Answers
  • Posted on Aug 30, 2011
Anonymous
Expert
Level 2:
Answers
147
Questions
Helped
44341
Points
409
Check all positive wires coming from battery sounds like you melted one and it's touching something it shouldnt, Thats what u smelled, clean and tape damaged wire(electrical tape) check wires behind fuse block also
1998S70 Volvo jump started it and put the jump
Hi. it sounds like you may have a faulty alternator get it tested at a local garage. Match your + and - on the battery terminals .
2answers
Car decelerating then jumping back to normal
Now iam not sure about this and no doubt iam totally wrong but as this is a later model and a american market version then it could be the fly by wire throttle control their is no cable but a variable voltage control inside the car and a electric motor on the inlet manifold and if this is the case i would suspect the pedal unit inside the vehicle ? but again no doubt i will get a verbal slap as being wrong .
2002 windstar wouldnt start jumped and started. then no start
Hi, chances are you have at least one bad battery cable. Check them with an ohm meter. If you have any resistance in your reading, say above 0.02 change your cable. Hope that helps.
2helpful
3answers
1997 ford escort battery new battery dead overnight no electrical works no blown fuses jump start and cables start to melt will push start and run
Check battery cables are correct ! Prime suspect here ! Alternator may be damaged and shorting .. Don't drive any car that will melt jumper cables ! Something very basic wrong here.
98 chevy cavalier 2.2....replaced starter...car wont turn over..no clicking...battery ok. car will start by jump starting the starter with a screw driver...replaced fuses...any idea what could be wrong?
Sounds like bad battery cables and/or ignition switch. I would clean battery cables thoroughly with wire brush especially the bottom end since they're exposed to road grime, etc... Also check to make sure you put small wires on solenoid on correctly. I've seen people get them reversed because they're looking at them upside down when attaching from under car. More than likely it's those small wires on solenoid.
2003 BMW 525i--could an improper jump start blow a fuse?
new altenator,sounds like you put the cables on the wrong way round
CAR WON'T START
yea sounds like u need a starter i think on that model its located behind engine under intake manifold u have to jack car up high to work easier there's 2 bolts holding it in and if i remeber correctly 1 is tough to get at if iam wrong on location just follow positive cable from battery and you will find it
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
