SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
SOURCE: BRown water and stuff coming out of iron
To clean the sole plate, Rowenta has a sole plate cleaning kit for $9.99, however, Dritz sewing notions makes one too and it is much cheaper. You take an old CLEAN dishcloth and squeeze about an inch of the cleaner on the towel. Using a hot, dry iron move it back and forth over the cleaner until the sole plate is smooth and clean. I then use a q-tip to clean any residue from the sole plate. Keep turning the towel until all the cleaner is removed from the iron. Any time my iron becomes sticky I use this method and it works great.
SOURCE: Rowenta Steam Iron Leak
Yes, my rowenta model DX6700 is also leaking from the heal. I bought this iron after having a GE for ten years because I thought it would iron my clothes better. I've had it less than two years. How frustrating!!!!!!
SOURCE: iron leaks water from the back end of the base
This problem is the way that rowenta seals the water tank. If the iron is disassembled and the seal is properly put on it will not leak,, however this seal is a silicone based product and not just an off the shelf gasket. I have sealed and repaired some using a high temp silicone
SOURCE: iron leaks water while ironing
Seal on iron is disolved. replace iron
Testimonial: "your information was very helpful."
