20 Most Recent Rowenta Professional Luxe DM880 Iron Questions & Answers
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Rowenta... | Answered on Jun 26, 2013
the temperature control needs to the greased or oiled so that it can be free. Use break oil, or engine oil, or something similar to free the control.
You will need to disassemble the iron to get to the temperature control.
I hope you understand the above. If you don't please let me know.
Regards.
Rowenta... | Answered on Aug 27, 2011
your plug needs replacement. you have to put high wattage plug ,because iron has 1000watts or 4 amphere load.
Rowenta... | Answered on Aug 17, 2011
you have a open circuit that occurs due to a wire loose at the plug end or a loose connection within the iron. a break in the cable will also display the systems you discribe. check for loose connections before you decide to replace the cable. by keeping the cable stationery when the iron is on at the plug end check wether it switches off when you move the cable near the plug end.if it switches off the loose wire is in the plug if it does not the try the moving the cable nearer the Iron end.
Rowenta... | Answered on Apr 10, 2011
Hi am having the same problem can it be fixed
If the iron doesn't heat, make sure power is on to the outlet, check the electrical chord, and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical chord . Also test and, if needed, adjust calibration of the thermostat.
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the sole plate. If the iron stains fabric, clean the sole plate, clean the tank with a commercial cleaner, and use distilled or filtered water.
The tools you will need are
  • Screwdrivers
  • Toothpicks or pipe cleaners
  • Sewing needle
  • Commercial electric iron cleaning solution or vinegar and water
  • Commercial sole plate cleaner or baking soda and water
  • Steel wool
  • Emery cloth
Please rate my solution.
Rowenta... | Answered on Mar 17, 2011
Have you tried to turn the pressure right up as far as it can go and see if the steam naturally comes out that way,
hope this helps
Rowenta... | Answered on Mar 03, 2011
I would try the white vinegar...
Also check out this tip...
Cleaning a Steam Iron White Scale and Brown Water
heatman101
Rowenta... | Answered on Sep 28, 2010
Hello. Begin by cleaning the iron as follows: Cleaning the reservoir requires the use of white vinegar and a clean rag. Fill the reservoir of a cold iron at least one fourth of the way with white vinegar. Turn the iron on and place it on the steam setting. Steam iron the clean rag until the reservoir is completely empty.
If the deposits are still visible to you, you will need to fill the reservoir with clean water and steam iron a rag again. If the deposits are still visible to you after this, you will need to repeat the process with vinegar until the deposits are no longer apparent.
Rinse the reservoir thoroughly with clean water by filling it completely and then emptying it completely. In order to avoid mineral buildup and deposits, use only distilled or purified water in the reservoir. If you continue to use tap water, simply remember to clean the reservoir periodically.
Vinegar has a strong smell associated with it, especially when it is heated. Ventilate the area where you are working as much as possible, by opening windows, turning on vents or fans, or keeping the door open.
Cleaning the Soleplate
Unfortunately, the soleplate of an iron is prone to occasional build up. Therefore, the soleplate requires cleaning in order to avoid staining the clothes or fabrics. Avoid abrasive cleaning powders or scouring pads.
Begin with a cold iron that is unplugged from the electrical outlet. Use a mild dish washing soap or laundry detergent to create a sudsy solution. Use a nylon mesh pad, sponge, or a clean cloth dipped in the solution to completely wipe off the soleplate of the iron. Wipe the soleplate clean with a damp cloth or rag.
If the soleplate is the victim of a starchy build up or corrosion of some form, you will need to use something a little stronger. Use a clean cloth dipped in white vinegar to remove the build up. Wipe the soleplate clean with a cloth dampened in clean water.
Rowenta... | Answered on Sep 17, 2010
Rowenta Professional Luxe DM880 Iron Logo
31 questions posted
Top Rowenta Irons Experts
Colin Stickland
Colin Stickland
Paul Bade
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
View Most Popular
Rowenta Irons
  • Rowenta Irons
Most Popular Question
rowenta steam iron
  • Irons
