SOURCE: my tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
SOURCE: Tricity Bendix washer won't take fabric softner in rinsing cycle
Your machine possibly has a defective water inlet valve which is preventing water from entering the dispenser channel to flush the fabric softner into the machine. The inlet valve in inside of your machine right where the washer hoses attach. the solenoid valves on the inlet will need to be checked with a multimeter to verify if they are working properly.
SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
SOURCE: tricity bendix aw1400w will not spin
We had a similar problem, where it washed okay but didn't spin and just 'beeped' with end light flashing. When the drum was empty it was not moving round very freely.
Try unplugging the machine from the electricity. Then take top off machine off so you can see the casing outside the drum. There's a small rubber tube on top. If you disconnect that you can look through into the drum. Try turning the drum round slowly while looking through the hole. We found a sock wedged in which we managed to pull out through the hole (not easy and don't expect the sock to come out in one piece).
It worked - and we've had to repeat the procedure a couple of times now. Think I must be putting too much in the machine in 1 go, although there's always space at the top.
SOURCE: manual for tricity bendix 1000
Please try here:
http://www.serviceforce.co.uk/pdfs/U23248.pdf
If this is your model (there are 5 models with the same name) please rate my response.
If not, please let me know and I will find the link for your model.
Thanks.
