You will have to be the computer administrator to change any values on any hard drive click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7 click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Turn on your computer and plug in the drive after your operating system has loaded.
Open "My Computer" and search the list of drives until you find your USB drive letter.
Right-click on the name and click "Properties." Once the options have loaded, go through the tabs until you see the option to remove write protection. If this does not work, go to the next step.
Visit the company website for your USB drive. Go to the help or support section and search for "write protection."
Click on the download section and search for "write protection software remover." Download the program and install it on your computer.
Open the software program. Go to "Option" and click "Remove Write Protection" to unlock your USB drive.
