20 Most Recent PNY Attache 64GB USB Flash Drive Questions & Answers
PNY 64gb attache is not recognized
Is it a usb3 device? and does your computer have usb3 ? Also a non formatted device will show up as a drive or device in device manager but not in my computer until it is formatted and if it wes formatted and working previously the FAT my be corrupt and require reformatting assuming the device is not damaged
1/29/2018 5:45:08 AM • PNY Attache 64GB... • Answered on Jan 29, 2018
PNY Attache 64GB usb flash drive Disk is write protected
Normally I'd make something this simple the very first step. Some USB flash drives come with mechanical switch on them that put them into Write Protected mode. There can be very small slider switch. And if this is the case, then you must move the switch to unlock position. Source: http://www.rescuedigitalmedia.com
1/20/2018 6:25:09 AM • PNY Attache 64GB... • Answered on Jan 20, 2018
How to remove write protection
How to tke write protection off a pny attahe? - Hard Drives ...
www.tomshardware.com > Forum > Storage
Tom's Hardware Guide Sep 22, 2012 - 6 posts - ‎3 authors Hello, I have a 64 gig attache 2.0 flashdrive. ... I could not see a write protect switch in the PNY product guide, but just ... I've been trying to do this for nearly a year and today found the tool to format my 64GB PNY flash drive. ... the Link you provided and downloaded the recovery tool for my PNY USB 64 Gb ... USB Flash Drive is write protected and shows up as ... 11 posts Nov 11, 2012 Remove write protect flash memory USB - Flash Media ... 15 posts Nov 30, 2009 More results from www.tomshardware.com
how do i take off my write protection off
1/16/2016 7:24:52 PM • PNY Attache 64GB... • Answered on Jan 16, 2016
Flash won't work after format
format it in fat 32 mode
5/7/2014 7:53:07 AM • PNY Attache 64GB... • Answered on May 07, 2014
Pny Attache 64gb flash drive will not format correctly
You can go to Administrative Tools>Computer Management>Disk Management and try to format it from there. You may need to delete the partition that is on there and create a new one. If you are still unable to format the drive correctly, contact the manufacturer and request a replacement.
3/14/2014 3:19:25 PM • PNY Attache 64GB... • Answered on Mar 14, 2014
0answers
0answers
When I insert my PNY flash drive 64 GB m
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp or earlier
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this or if i have missed the problem post a reply
hope it helps
11/8/2012 6:58:18 PM • PNY Attache 64GB... • Answered on Nov 08, 2012
How to fix PNY USB flash drive
Salutare bai Lucica... Vad ca ai probleme.. cu stick-ul :)Daca ti-l vede ca unitate, in My Computer, descarca HDD Low Level Format Tool de pe http://hddguru.com/ .... descarci, instalezi si ii dai o formatare low level la stick... o sa zbarnaie dupa aceea... multa bafta
9/22/2012 9:34:10 AM • PNY Attache 64GB... • Answered on Sep 22, 2012
2answers
Data recovery
There are many freeware and pay data recovery programs available on the web Try this freeware call smart Data Recovery http://www.smartpctools.com/recovery/ind... This is different from other recovery software because it not only recover lost file from harddrive and floppy like most do, but also recover from removable media like flash drive. http://download.cnet.com/pandora-recovery/3000-2094_4-10694796.html File recovery has never been easier thanks to Pandora Recovery. The program's wizard-like approach to finding and retrieving lost files will appeal to all users. http://www.piriform.com/recuva Accidentally deleted an important file? Lost something important when your computer crashed? Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
4/15/2020 10:09:25 AM • PNY Computers &... • Answered on Apr 15, 2020
2answers
Installation cd
go right to their website and download the appropriate driver/software and install it from your computer instead of the cd. incidentally, remove the cd from the drive and inspect the working side... the shiny side and see if it has any smudges or scratches. the cd player may not be able to read it.
it's not mentioned but is that a pc or mac and what operating system are you using ?
Robert
4/29/2019 9:08:10 PM • PNY Computers &... • Answered on Apr 29, 2019
FORMAT PNY 32GB
Try downloading and using the PNY format tool for 32GB flash drives: https://www.pny.com.tw/index.php?cls=2&mode=download https://www.pny.com.tw/index.php?cls=2&mode=download
11/20/2018 10:35:39 PM • PNY Computers &... • Answered on Nov 20, 2018
I have a 32gb Memory card that has a lot of
Try to scan the Memory card or Try to use bluetooth if the camera had bluetooth
11/14/2017 5:46:59 AM • PNY Computers &... • Answered on Nov 14, 2017
2answers
PNY GeForce GT 630 drivers are preventing windows vista from starting
Check the software for the new part, is it compatible with your version of Windows, I think that is the likely problem.
4/25/2017 11:14:52 PM • PNY Computers &... • Answered on Apr 25, 2017
I need to replace my nVidia GeForce FX 5700-VTD256 graphics card
get a different monitor that can handle it or get a better motherboard ram etc
5/8/2015 10:27:17 PM • PNY Computers &... • Answered on May 08, 2015
Geforce gt 630
Ok, so when you put the card , even at start you can't see nothing or just at windows start ?
9/28/2014 2:45:17 PM • PNY Computers &... • Answered on Sep 28, 2014
PNY Attache 64GB USB Flash Drive Logo
13 questions posted
Top PNY Computers & Internet Experts
Marvin
Marvin
Larry Ng
Larry Ng
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • PNY Computers & Internet
Most Popular Question
pny 64gb attache not recognized
  • Computers & Internet
