SOURCE: Zhone 6212-I3-200-0PA, What is the
its usually default:
admin
admin
or
admin
pass
or
admin
(no password)
try them and let me knw how you get on?
SOURCE: i have a Zhone ADSL2+
Please use the following steps:
1. Remove the router and connect it directly from the pc to the modem.
2. Power cycle: turn the modem off and then the computer for 30 seconds, then turn them both back on, modem first.
3. Check you internet connection to see if it working.
4. If it working, connect the router back up. If it not working contact your ISP for dsl support.
5. Once the router is connected, release/renew the ip address. Go to the dos command type ipconfig/release press enter. Then type ipconfig/renew. Check your ip address, you shouldn't get an ip address starting with 169. If you do, this mean you have a problem with the router getting an ip address.
6. Check you internet connection after the release/renew
SOURCE: My Zhone 1518-A1 modem-router keeps loosing
Its normal for the internet light to blink, it means that its having an activity.
Try accessing the modem GUI (graphic users interface) and then change the WEP key or security key , if the modem-router is not password protected then just reset it.
You can also change the power values on it
Hope this helps
Thanks
Dennis
