Question about Zhone 1518-A1-NA Wireless Broadband Router - 54 Mbps 1 x ADSL Network WAN, 4 x 10/100Base-TX Network...
My Zhone 1518-A1 modem-router keeps loosing internet connection although wifi connected. Is it normal that the internet led is blinking?
    New Friend:
  • 55 Answers
Its normal for the internet light to blink, it means that its having an activity.
Try accessing the modem GUI (graphic users interface) and then change the WEP key or security key , if the modem-router is not password protected then just reset it.
You can also change the power values on it
Hope this helps
Thanks
Dennis
Posted on Nov 10, 2011
6ya staff
SOURCE:
How to increase zhone 1518 internet speed
Many things/variables determine Internet Speed, some you can control, some not so much. Contact your ISP and have them verify the signal, have a ISP tech come out and analyze the signal. The issue may be outside equipment or the Internet site itself. No one thing will increase speed. Upgrade to a New N or AC Wireless Access point, but remember you must update ALL computers to N or AC to benefit fro the Wireless device upgrade. Check ALL cables and connections, reseat connections. Your Device is a 802.11 G, what are you connecting? Are the Computers G as well? You can connect via a Ethernet cable, that's the fastest/easiest/cheapest way to increase speed.
Mar 11, 2013 | Zhone Computers & Internet
What is the Username and Password for a Cavalier provded Zhone 1518-A1 Modem Router?
If the Zhone 1518-A1 was provided by Cavalier, then the address is:
192.168.1.1
Default Username: admin
Default Password: [email protected]@l13r (all lowercase)
This information was valid as of 01/17/2013
Jan 17, 2013 | Zhone 1518-A1-NA Wireless Broadband Router...
Only you know your SSID( username)and Security Key(password). You can RESET the device to default settings by pushing and holding the reset button for 30 seconds or so and release. That will reset to default setting. Then you can reconfigure the SSID and Security Key, You may want to write down the info for future use. This may help: http://www.zhone.com/products/1518-A1/
1518-A! router
Click Start on your computer then Run and type cmd then press Enter.
When the DOS command box opens then type ipconfig and press Enter The computer will the display the IP address that was issued to your computer BUT if the IP address is 0.0.0.0 then your router did not issue an IP address to your computer and you need to repair the network connection.
Oct 03, 2012 | Zhone 1518-A1-NA Wireless Broadband Router...
I need the default username and password for the Zhone 1518-A1 dsl router i cant find it or figure it out please help
192.168.1.1
This information was valiad as of 01/17/2013
Aug 16, 2011 | Zhone 1518-A1-NA Wireless Broadband Router...
I have a Zhone ADSL2+ 4 Port Wireless Bridge/Router, model number 1518-A1-UK-0MA. it as working perfectly until one day when i turned it ON, only the ADSL LED is lit, no other LEDs are on, nor the power...
Please use the following steps:
1. Remove the router and connect it directly from the pc to the modem.
2. Power cycle: turn the modem off and then the computer for 30 seconds, then turn them both back on, modem first.
3. Check you internet connection to see if it working.
4. If it working, connect the router back up. If it not working contact your ISP for dsl support.
5. Once the router is connected, release/renew the ip address. Go to the dos command type ipconfig/release press enter. Then type ipconfig/renew. Check your ip address, you shouldn't get an ip address starting with 169. If you do, this mean you have a problem with the router getting an ip address.
6. Check you internet connection after the release/renew
Jun 10, 2011 | Zhone 1518-A1-NA Wireless Broadband Router...
This zhone 6212-13-200 modem continually connects, disconnects
you will need to use the power supply that came with the zhone
router......other power supplies are not interchangeable.
make sure all other items that are pluged into the other phone jacks
have inline dsl filters....do not filter the router...if you have the whole
house filter on the outside of your house you will not need to put inline
filters inside ...
make sure there are no loose connections...
last call you isp provider
Jan 02, 2010 | Zhone 6212-I3-200 Router
Can't use p2p programs with my 6211-I2
Make sure there is no firewall running. Even the windows xp firewall can screw up p2p applications.
Aug 17, 2007 | Zhone 6211-I3-200 Router
Zhone 1518-A1-NA Wireless Broadband Router - 54 Mbps 1 x ADSL Network WAN, 4 x 10/100Base-TX Network... Logo
827 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Joe Goldman
Joe Goldman
Mike
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
