SOURCE: Power light going to blinking amber
Sounds like a problem in the monitor's power supply. This will need component-level troubleshooting.
SOURCE: "Auto" always worked but now messed up; can't fix
I had same problem and eventually it died after degrading further a few months later. Other monitor works great...
SOURCE: 17" lcd monitor V7
90% of LCD monitors failures are due to bad caps, as you can see in my albums.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Bad caps:
Testimonial: "thanks bro "
