20 Most Recent Dell P780 17" CRT Monitor Questions & Answers
I am assuming you are talking about your monitor. What this message means is that your monitor can't handle the resolution your video card is set to. Re-start your computer and as soon as the first screen goes by (you know the one with all numbers and stuff) start hitting the F8 key. This will start the computer in safe mode which uses a very low resolution (usually 640 x 480). Once you see the display set the resolution to 800x600 which any display can handle. Re-boot and log in again and change the resolution to something higher. Test different settings. If you set one that is too high and you can't see the screen again don't touch anything as the screen will revert back to the previous setting if you do not confirm.
Hope this helps. If it does don't forget to give me a thumbs up.
Dell P780 17"... • Answered on Aug 29, 2011
You computer monitor is not receiving a signal from your computer system. Be sure to check that all connections are indeed making good contact.
Go through my published guide in this regard, it is entitled
My Computer is not turning on!!! Is it dead!!! No POST!!!
damnor01
Dell P780 17"... • Answered on Apr 04, 2011
It probabily happens after you change the settings of display in control panel (windows), if so restart the machine and press function key <F8> after memory test and you shoud get to the startup menu, choose VGA mode and undo the changes in display that you have made.
Best Regards
Creon
Dell P780 17"... • Answered on Jan 25, 2010
That sounds like a monitor issue, not a video card. Gradual fading means components within the monitor are wearing out. However, I strongly advice against attempting repairs. CRT monitors hold a strong electrical charge. People have been injured and even killed by attempting to work on them without proper tools and training. A 17" CRT monitor is too cheap to be worth the risk (you can often get them used... I got mine for $20 at Goodwill).
Dell P780 17"... • Answered on Jan 23, 2009
Hi
Click StartGo SettingsControl Panel  Display Settings your screen 1024*768 select  it and 32 bit color quality also.. apply it ok..
it will work.
Dell P780 17"... • Answered on Nov 18, 2008
Sorry to say but it sounds like your deflection is on it's way out.
The best option would be to get a cheap used LCD now while you have the chance since repair of your current CRT will cost as much if not more.
Dell P780 17"... • Answered on Apr 08, 2008
Greetings to you! This error is due the battery. The battery didn't get sufficient power supply. If you are using the duplicate battery I suggest you to purchase a genuine battery from the authorized reseller. before that try the following steps as a first aid and it may help you. follow each step
  • First of all, remove the battery on your Dell laptop.
  • Turn over the Dell laptop.
  • Then pull out to remove the battery
  • Wait a few minutes at least 50- 60 seconds.
  • Next, start your Dell Laptop.
if this steps didn't work out then it is better it to the authorized service provider and get your gadget replaced with the genuine battery thank you!
Dell Computers &... • Answered on May 02, 2021
I haven't before this heard of such a thing. I am wondering how you have determined this figure and what exactly you mean - do you mean the 1TB drive is now considerably less than 1TB? Perhaps you mean the available space on the drive is reducing by 10Gb per day? If the latter it suggests your computer is downloading lots of stuff without your knowledge and if the former it suggests the hard drive is failing. I suggest you connect your hard drive to a different computer via a usb adaptor and run the check disc utility and examine the contents to discover whether there is content on it you didn't put there.
Dell Computers &... • Answered on Apr 07, 2021
Download Offline NT Password & Registry Editor (USB version) from this link http://blog.omotech.com/?p=830 and follow the prompts to bypass admin password
Dell Computers &... • Answered on Mar 12, 2021
Hi there, Have you tried using VLC player? http://gofree.com/download/Video/Media-Players/vlcmediaplayer.php?gclid=CO6F9b62l6kCFcK8KgodrnOGvw VLC will play almost any video. If VLC doesn't it may be safe to say your video is corrupted. Alex
Dell Computers &... • Answered on Feb 27, 2021
Files that contain the .edb file extension are most commonly used by mailbox data files that have been saved by the Microsoft Exchange Server.
Dell Computers &... • Answered on Feb 17, 2021
open a gmail account and see if the issue continues
Dell Computers &... • Answered on Feb 01, 2021
Click on Start ' Control Panel ' Power Options. Set the Turn off Monitor/ Turn off Hard Disks option when on Power (and also Battery for laptop users) to Never.
Dell Computers &... • Answered on Jan 31, 2021
why not ask at dell.com (sure the endless laughter and taunts) ;-) is this a laptop, and is useless now. totally. but the battery is bad, remove the big battery it is shorted now. then the coin cell battery went dead 2 decades go. and now the HDD is bad. why in the world waste or worse money on this junk far far better fish in the sea, far newer, and cheap. used. this lappy has CCFL back lamps that went bad long ago. no fix for that under $100. this PC has no value at all, why mess with this pig.
Dell Computers &... • Answered on Dec 24, 2020
If that is the correct model, there are instructions at the link shown below to disassemble it. (Thank you, Larry NG ,for determining that Anonymous made typing errors spelling the model.) You may want to ask a trustworthy friend to help you with this if needed. http://www.insidemylaptop.com/disassemble-dell-inspiron-17r-n7110/ How to disassemble Dell Inspiron 17R N7110
Dell Computers &... • Answered on Dec 21, 2020
ok I give up. no problem stated at all like LCD cracked? ok 2709 is only a screen , i had to google that just to know that. so my guess your questions is how to dismantle THIS monitor so what be first, RTM we read the manual first, but dell its missing they are afraid you will get hurt i guess. the manual was leaked to here. dell.com has user manual but not service, there. but here it is. see page 35 , begin take down, you question is wrong, the question is what comes off first. before bezel. https://www.manualslib.com/manual/910263/Dell-2707wfp.html?page=38#manual
Dell Computers &... • Answered on Dec 14, 2020
It alway zs helps to know the model number. Witht that information, you should be able to find the specifications at the Dell support site. It would simply tell you in a specs sheet. I guess you could download HWinfo, a handy freeware program and check informaiton about components there. There is of course the option to download the user manual.
Dell Computers &... • Answered on Dec 13, 2020
case size what? (this tell what mobo is inside) yeah.OS is what window 10?what is in your hand USB? device, cant guess that.do all ports fail?is USB 2 and 3 ports all turned on IN BIOS F2 pages.does keyboard USB fail on any USB portsdoes it fail in BIOS windows only or that and BIOS screens too. if fails in BIOS too, that means the ports some are tuned off in BIOS.
Dell Computers &... • Answered on Dec 09, 2020
Dell P780 17" CRT Monitor Logo
12 questions posted
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
View Most Popular
  • Dell Computers & Internet
Most Popular Question
monitor working out scan range
  • Computers & Internet
