SOURCE: How to format the LaCie 500GB d2 Quadra for Windows XP??
This way it should work...
Connect your drive to the computer...
Go to: Start > Control Panel > Administrative Tools > Computer management.
A new window will appear...
Select Storage > Disk management on the left of the window.
Now you will see the different drives that are connected or part of your system.
One of the drives listed there is your LaCie, i think you'll recognize it by name...
Right-click on it, and select 'format'
In the new window, select the new volume label (as you like it), the file system (use NTFS), and set allocation unit size to default.
Make sure 'Perform a quick format' is not checked...
Then click OK. Your drive will be formatted now... Don't interrupt the process
SOURCE: How to i reformat a lacie 500gig external hdd
The Mac OS can't natively write to NTFS (it can write to FAT32 however). But if you install MacFuse followed by NTFS 3-G on OS X then you'll be able to write to your NTFS drive.
SOURCE: Is my LaCie External USB 2.0 500GB fried/dead???
Does it make any clicking/clunking sounds like any of these?
If yes - it's really bad and there's nothing you could by yourself..
If it sounds normal or doesn't spin up at all then try to remove it from enclosure and connect directly to a PC.
SOURCE: LaCie 500GB external will not
Did you format the drive using Disk Utility? Open "disk utility" from the dock icon or applications/utilities folder. Click the drive name on the left side of the disk utility window. click the "partition" tab in the window, next click the "options" tab and select GUID Partition scheme, or any Mac compatible scheme, read each explanation of the schemes. Name and resize your partitions, click apply. This is how it works running Leopard, not positive if the same applies to Tiger. I hope this helps you
SOURCE: Lacie 500gb quadra external drive won't boot using USB cables.
Microsoft has had some issues in regard to external devices (especially after running some updates). There is a registry patch for this situation. Click below to install the patch. It should fix your external drive problem. All the best!
Greg
http://support.microsoft.com/kb/925196#fixit4me
