42" will more likely to use Metric M6 screws (canbe M5 but not likely), the length of the screws will depend on the thickness of the mounting plates. When you buy wall mounting kit, it will come with mounting screws. You can get Metric screw from HD or Lowe's for about 50 cents each.
I get my wall mounts from Costco and they come with a bag of Metric screws fro mounting.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
SOURCE: wall mount hardware
The bolt size you need is: M8-1.25 X 20. 20 is the length that I used and it works well. You could also use 25 (which is a little longer) if you would like. It took about 5 trips to Home Depot and Lowe's and a few hours searching the web before we got it right.
SOURCE: remove tv from wall mount
there is an anti theft device on the wall mounts you need the manual to adjust mount to take off
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=255670bad135aec3653b726b698def9d&q=Samsung+PDP4294
heres the link just follow instructions to get download i will also be posting it here on fixya too
this the manual
SOURCE: 42LC7D-AB cant find bolts to fit for wall mount
http://www.scribd.com/doc/6399173/LGTV
here is the owner manual. look on page 16 and you will see one way to wall mount. Ragarding the size of the bolts needed, go to the hardware store and get one bolt of each size close to what u think u need and use the trial and error method. OR go to an electronics store and ask one of the techies. Be nice and they will help u for free.
SOURCE: Tv didnt come with screws....
The size is #8-40 X 3/4". This is a specialty screw, so you're screwed
SOURCE: screw size to bolt panasonic 32 inch lcd into
Metric M5 or M6, they should come with the mounting kit.
