20 Most Recent Razor 300001-SL Ground Force Go Kart Questions & Answers
replace thumb tab throttle. part is $12.99 from razor. go to razor site to order. i had the same problem after my daughter drove it over a bumpy sidewalk.
Razor 300001-SL... | Answered on May 05, 2018
I don't think this would be a problem, as long as the wheels fit the axle properly, both in diameter, and length of shaft.
Razor 300001-SL... | Answered on Dec 02, 2014
This go cart does not have reverse, so positive & negative wires must be switched.
Razor 300001-SL... | Answered on Dec 02, 2013
test the motor with your own battery. connect the battery directly to the motor if that work is the controller, easy.
Razor 300001-SL... | Answered on Oct 29, 2012
Here is the owners manual for the future (in case you don't have one.)
http://www.meijer.com/assets/product_files/pdf/1000422_groundforce_manual.pdf
It sounds like the push button fuse next to your charging plug. Push that in and try again. Otherwise it could be a wiring defect.
Razor 300001-SL... | Answered on Aug 23, 2012
Hello, I believe what the problem is, in your throttle switch or more often the connection to your battery, even though your battery might be good, bad or loose connection can cause this. Most electric toy cars, go carts, buggies, and other similar electric toys, all operated on a electrical switch mechanism. They are effective when working, but unfortunately from my experience poorly built, meaning they wear out real easy. When working properly, you press the pedal, activates the electrical circuit by way of the switch. Think of the switch as like the ignition on a automobile. It works kind of the same method.
I believe personally it is in your connection to your battery. However here is what did here to help you out. I have put to REAL GOOD links to help you. One link is to the sight, which shows you parts and cost for parts, and on same site i gave you the link that takes you to the Ground force trouble shooting guide of possible problem and solution based on the symptom. I think this will help you. Links are below and please copy and paste them in your browser and let me know if anything else i can help you with. Thanks Mike
http://www.razorama.com/razor-ground-force-drifter-parts-section.html
http://lib.store.yahoo.net/lib/razorama/GFtroubleshooting.pdf
Thanks Again, Mike , (Fiya Expert.)
Razor 300001-SL... | Answered on Aug 04, 2011
Razor 300001-SL Ground Force Go Kart Logo
47 questions posted
Top Razor Toys Experts
ROB
Andrew Taylor
Andrew Taylor
Dennis Key
Dennis Key
Are you a Razor Toy Expert? Answer questions, earn points and help others
View Most Popular
Razor Toys
  • Razor Toys
Most Popular Question
39 ve replaced batteries
  • Toys
