Razor 300001-SL Ground Force Go Kart Logo
A
Anonymous Posted on Nov 02, 2013
Razor go cart does not turn on - Razor 300001-SL Ground Force Go Kart
Why doesn't it run?
Try battery first check with digi. volt ohm meter, but yes it could be module.
1helpful
Razor Scooter ground fOrce go cart wont go
The E100 is a Kick Start scooter, the Rear Wheel has to be Spun for it to start. This scooter will not start from a motionless position.
Could be the battery.
Put the Scooter on a block so the rear tire is raised. Remove the standing plate to reveal the battery compartment.
Charge the Unit completely
1. Using a multimeter measure the voltage across the batteries. If the voltage is below 20 volts batteries are dead - Replace batteries.
2. Now for a running test. Turn the throttle and spin the rear tire to preform a kick start. Still measuring the voltage. If the voltage is Below 20 volts or if the voltage drops quickly batteries are dead - Replace batteries.
3. If the voltage is remaining around 24 volts for a long period - then you could have connector problems, clean and tighten all connectors.
I use a fiberglass electronic cleaning brush, as contact cleaners leave residue that interfere with electrical connections.
See my other posts for E100
Razor ground force go cart
I don't think this would be a problem, as long as the wheels fit the axle properly, both in diameter, and length of shaft.
3helpful
Dull razor blades after moisturizing stripe wears off
Expensive replaceable cartridges are only made to offer 4-6 "good" shaves for most people. Sorry - that's the deal. You can strop cartridges (in on direction only) on denim and pick up maybe a dozen more - search youtube for examples. I finally gave up on carts and moved to a straight razor; a razor or two will last for a lifetime with good care. There IS a learning curve for safe use and maintenance procedures. Find a straight razor forum if you want great shaves and good advice on what to buy, what not to buy and how to be safe.
Double edged safety razors are also a very good alternative for better, smoother shaves and WAY less expensive blades. Same advice - find a razor forum to save money, buy right and avoid nicks.
Replaced transformer
This go cart does not have reverse, so positive & negative wires must be switched.
My razor dune buggy won't drive
are you sure that the charger is putting out enough volts to charge the batteries? check the charger with a multimeter, then check the batteries with a multimeter, and viually inspect the batteries for bulging
13helpful
4answers
Razor Ground Force Go Kart will not work.
replace thumb tab throttle. part is $12.99 from razor. go to razor site to order. i had the same problem after my daughter drove it over a bumpy sidewalk.
Top Razor Toys Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Kardoc
Are you a Razor Toy Expert? Answer questions, earn points and help others
