20 Most Recent LG LRSC26920TT Side by Side Refrigerator Questions & Answers
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
LG LRSC26920TT... | Answered on Aug 05, 2011
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
LG LRSC26920TT... | Answered on May 04, 2011
When the refrig is running, the fan in the freezer section should be blowing air. Check for frost build up preventing the fan blade from turning.
LG LRSC26920TT... | Answered on Mar 06, 2011
the icemaker arm on the L g are diferent dont try to pull up not a shut off arm this has a switch under side of ice maker if u kift up on the arm on this icemaker yo uwill need to buy a new icemaker and they arent cheap check for an ice jam between auger in icemaker if you havent pulled up on arm ive also seen the water fill tube to icemaker frozen
LG LRSC26920TT... | Answered on Jan 28, 2011
I'm having trouble identifying that model number, but I can give you the generic answer. On most icemakers the "shut off" is lifting the wire arm to the up position. It should lock in that position. Lifting the arm shuts it off in the same manner that it stops the ice maker when too many cubes are in the tray. I have seen some icemakers that actually have a swich on the front side of them. But, they are in an obvious position so I'm guessing you don't have that style.
Hope this helps
The lights inside the refrigerator are not turning off when you close the door .
The light switch is broken. replace the door operated light switch.
LG LRSC26920TT... | Answered on Nov 26, 2010
If your refrigerator is not cooling, the problem could be any of the following, follow the steps below one after the other to fix the problem of your refrigerator not cooling.
First of all, the most simplest thing to do is to check the temperature. It might have happened that the temperature control may have been turned off unknowingly, which is the reason for the problem. So if that's the issue, just set the refrigerator at 37 degrees and you are all set.
Poor coiling leads to a heavy frost build up on the evaporator coils. A frost build up, specially on the ceiling of the freezer, is a sign of problem in the self defrosting system or damaged gaskets of the doors. Therefore, check if the refrigerator is facing such a problem and defrost the refrigerator. It would not cool well if the defrosting is not happening properly.
A dirty condenser may be the culprit for your refrigerator not cooling well. What will happen in case if the condenser is dirty is that it will cut off the extra load. That work is done by the thermostat on the side of the compressor in case the refrigerator heats more than usual. To rectify this problem clean the condenser coils using the vacuum cleaner. These are either behind or beneath the refrigerator
In case the refrigerator is not leveled, that too can lead to the refrigerator not cooling properly, because if the level is not right, the door of the refrigerator may not close correctly, causing cooling problems. If this is the case, it might be necessary to ensure that refrigerator is at level and is slightly tilted back. Do some adjustment to get that correct level using a wooden block or see if the screws on the leveling legs need some looking into.
Check out the door seal. If the door seal is worn out, it will definitely result in frost build up and that won't allow the door to close properly, thus the problem of refrigerator not cooling. In addition to that there can be a problem in the door even if the level and other things are fine. You would need something to do about the door then. May be loosen the hinges and fix them in order to get the correct position of the door. Eventually tighten the hinges.
The food and freezer sections will go dysfunctional if the evaporator fan is not working properly. This is because then there will be no airflow to the freezer or the other sections of the refrigerator. Confirm if both the fans are working well by listening to the sound emitted by them. There is a possibility that one may work and the other wont. For that, may be you would have to look for a blockage or something in the one which is not working. Even after doing this you do not find any problem in the fan, you may need to replace it. This are are the general procedure for troubleshooting refrigerator not cooling. with all this, you should be able to identify and fix the problem.
Take care.
LG LRSC26920TT... | Answered on Aug 22, 2010
Hello. Go to: http://www.searspartsdirect.com/partsdirect/merchandiser/show.pd?description=Home%20Appliances
Click on find the right part. Then you will see a blow up of the door. That way you will see how to get to the door handle screws and tighten them.
Please rate my answer as very helpful. thanks
LG LRSC26920TT... | Answered on Mar 27, 2010
There are many things that can cause this. It can be the icemaker itself. It can be a duct oroblem or even a fan. Also a small leak in the sealed system. In this case you should call a factory authorizes LG tech to diagnose the problem.
LG LRSC26920TT... | Answered on Jan 24, 2010
LG LSC26905TT.
How do I change the ice tray, it is bent.
Thanks.
LG LRSC26920TT... | Answered on Aug 08, 2009
You can go for UNIVERSAL DOOR HANDLES.
You can refer :-
http://shop.ukwhitegoods.co.uk/Refrigeration+Parts/Universal+Parts.htm
http://shop.ebay.com/items/?_nkw=universal+door+handle+refrigerator&_sacat=0&_trksid=p3286.m270.l1313&_dmpt=Motors_Car_Truck_Parts_Accessories&_odkw=universal+door+handle&_osacat=0
Hope i helped.
Thanks for using " Fixya".
LG LRSC26920TT... | Answered on Jul 11, 2009
LG LRSC26920TT Side by Side Refrigerator Logo
41 questions posted
Top LG Refrigerators Experts
Michael Thomas
Michael Thomas
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
LG Refrigerators
  • LG Refrigerators
Most Popular Question
am looking
  • Refrigerators
