20 Most Recent
Sony DCR-HC62E Mini DV Camcorder Questions & Answers
Where is the date battrry ??????????????????????
I don't know. The manual doesn't say or show you. However, you shouldn't need to change this battery. It is rechargable, and automatically recharges when the main battery is connected or when the battery charger is connected. The manual says that it will discharge (forgetting the date, etc,) after about three months when the camera is not used, so you would have to set the date again, but that doesn't mean you need to change the battery.
The LCD touchscreen has stopped working
Had the same problem. It's ainternal flex wire connecting LCD with camcorder. Got from the repair shop did it by miself and it's like knew. It's very common in sony. Good luck
Meggita
How do I clean a Dyson DC 23 so it will pass quarantine inspection when moving overseas (to New Zealand)
you will to ontact the customs office in Kiwiland for that answer. In most cases cleaning the hopper in warm soapy water and buying new filters is enough. Some places require a hospital grade detergent such as wESCODYNE be used to include the air hose(s). Please beware, the AC power in AU/NZ is 230 VAC, so you will need a step down power transformer to use it there. (You'd be better off just buying a new one there to be honest, then you needed worry about lugging a heavy power transformer around of changing the plug end to the Clipsal type used in AU/NZ.)
