20 Most Recent
Holley 1986 86 Dodge D150 Fuel Pump-1986 Dodge Fuel Pump Questions & Answers
How do i adjust the carburetor
there will be a plug at the side top of the fuel bowl that you remove to check and adjust the float level while running
the float level is adjusted by the bolt at the top of the cover above the needle and seat adjust until the fuel is level with the threads of the plug
screw that mixture screw/s in all the way then back out 1 1/2 turns
start the engine and adjust the idle speed by the screw on the accelerator lever
set to around 800 rpms
adjust the mixture screw in until the rpms start to slow
now screw the mixture out until the rpms again slow
mixture adjustment is achieved by turning the screw back in 1/2 the turns that you used to turn it out from the slow in position to the slow position out
again adjust the engine rpms by the accelerator screw to the 800 rpms
most engines idle between 700 and 850 rpms unless and efi engine which have around 850 -950 rpms range
How many time is normal mask life ?
it depends on the quality of the mask and it depends on how you stored it (if you leaved it at sunlight, if you washed it thoroughly after using it in the sea...)
i have a mid quality mask Mares mask, i have been using about 20 times for snorkeling, then i used it to take diving certifications in pool, then i used it for about other 20 dives in the sea... i always stored it in a dark bag (the mask is now about 8 years old)
you can check if you mask is still in good shape, and the silicone has not worn out, in this simple way: just put the mask on your face without straps.. remove all the air inside the mask by inhaling with your nose.. then look at your feet (keep inhaling): if the mask remains on your face you can keep using it
If i lay a pipe 6 inches below the surface of the
I would say no. The water in the pipe that is above sea level will drop back in the pipe until it reaches sea level. Provided neither end of the pipe whether above or below the sea is blocked the level in the pipe will always find natural sea level so it wont be higher or lower than sea level. So in answer to your question No it wont pour out.
Hi Folks I think everyone thought I have a baby
I noticed another FixYa guru here answered a question on another strand that applies to yours:
Also, please note this person on FB claims to be the Lemax fix-all guru. You can ask them more specific questions:
http://webcache.googleusercontent.com/search?q=cache:0YBPB3sM28kJ:https://www.facebook.com/eHobbyTools%3Ffilter%3D2+&cd=10&hl=en&ct=clnk&gl=us
The Knex website has building help for this problem. There answer is as follows:
Make sure all rods and connectors are fully hooked together, especially the blue and gray connectors. Even one peice not fully hooked together can twist the model just enough to jam the gears. (You may have it hooked together correctly prior to jam problems so it is good to check since I found a loose on holding the motor.) The chain links need to all be attached in the same direction, and fully hooked. The chain also needs to be on the tower with the hooks facing down and in as the chain runs on the outside of the tower. (Chain should be outside on the front and inside in the back with the 5 yellow bar side in the front.) Check that all gears are positioned correctly according to the instructions and the teeth facing the correct way. If you are still unable to get the seat to drop, you may remove the top yellow cross rod that the chain runs over - the model will also work with this piece removed.
I did all of these steps with my son and his still had trouble dropping all the time. It still seems light so the seat didn't have enough weight to drop with gravity during the non-moving cycle of the orange half gear. We decided to tape on 2 marble passengers to see if that helped. It did!!! When searching for other solutions, I noticed a UTube video that added people also so this seems to be a common solution. Try it or some other light weight added and see if it solves your problem.
I am looking for a
You're talking ancient history here. You might find a manual, but critical parts were unobtanium many years ago. Display it on a wall and call that good.
My netbook is net broke
Hello, There is one thing on some computers that will restart it like the day you bought it, see if there is a very small symbol that looks like a shooting star taking off from the ground and making a U turn and back down that\'s the best I can do for what it looks like, it will be only about 1/8 th in. tall and 1/16 th in. wide very small, it should be close to the power on button on your comp. this is a Rescue System to start all over from day one, I have a Lenovo G570 Laptop and it has one of these, thank god as my comp. got a very sick and would not even let Windows start up I pushed this button and I was able to clear all the stuff that was stopping it from opening, if your lucy you will have something like this on yours, Look it over real close to find this symbol, sorry I don\'t have a pic. for you, you could also check if there is a Tech. help line for your brand of comp. Well I hope this may help in some way, and get you back on line.
My spairair system has a slow leak, how can i fix
Dave,
Good luck with that...... A MUCH more reliable way to go is a small pony bottle, say a 13cf with an inexpensive reg and a pressure gauge /plug or better yet a regular SPG.. That way you have a real reg with a whole lot more air with which you can more comfortably share air or hopefully save yourself or do a bit of a safety stop on the way up.
What type of information do dive computers display?
Dive computers
display a large variety of information relevant to the diver's needs. Such
information includes: Current depth, elapsed dive time, and how much time
remaining the diver has before having to make decompression stops.
