Question about Scuba Diving & Snorkeling
Im getting condensation between the mask and the head gear. I'm using a airtouch F20 fullface mask cushion
Posted by Jason Terrell on
Robert Soer
Try to spray the commercial available mist to lower surface tension in order to avoid build-up of condensed water
Posted on Nov 02, 2018
Dog ate the ear cushion on my AblePlanet NC180BMM Black Noise Canceling Headphones. Can I replace?
what --the dog or the head phones
the ear cushions may be difficult to get and it may be best to get new head phones
dogs you can get from the pound
Dec 12, 2016 | Audio Players & Recorders
I have a 1996 Opel astra 2.0l 8valve what can l do to give it more power.
remove 1600 gear box because is too small but when putting a 200i engine u must change the gearbox too and put f20 super boss gear box or put f18 gear box when not finding f20 for 200i because f18 and f20 gearboxes is using bigger clatch plate but f20 is the most pawerfull gear box because I use it on my opel kadett earo and the car is running good
Sep 16, 2014 | Opel Astra Cars & Trucks
How do you replace drive indecator light
1. Lift the little carpet in the console rear to the automatic gear shift. Pry with a small flat screwdriver will do the job.2. Remove the three Philips head screws.3. Remove one Philips head screws on each side of the rear console, they are located at the bottom front of the rear console panel. You may have to move the driver and passenger seat back to see the screws.4. Grab the back of the rear console and gently wiggle, pull backward and lift upward. Pull the hand brake so it is easier to remove the loosened rear console panel. 5. Use a flat head screwdriver to pry the rectangular 'cushion' around the automatic gear shift. Gently pry at various spot and the rectangular 'cushion' will come off easily.6. Now you are just one more plastic cover away from the burned bulb. The plastic cover that has those 'P'ark, 'R'everse, 'D'rive letters is held in place by four snap on latches. Use a small flat head screwdriver and gently push the black latches inward in a downward motion, once the screwdriver head gets inside the grey latch holder it will free the black latch. Work on each of the four latches in turn.7. Wiggle the plastic cover until it is completely loosened from the four latches. Gently lift the plastic cover up. The automatic gear shift will stop the plastic from being lifted out completely. You still have enough room to work with. You will see the little burned bulb directly below those 'P'ark, 'R'everse, 'D'rive letters. Gently pull the bulb out. I got my replacement bulb at Canadian Tire, Motomaster instrument replacement bulb 194LL (clear, long lasting, 2 bulbs for $2.99Cdn). It is a push-on bulb.8. Test the bulb by starting your car and dash lights.9. Snap back the plastic 'P'ark, 'D'rive cover. Put back the rear console panel and finally the rectangular 'cushion' around the automatic gear shift.
Dec 17, 2011 | 2006 Toyota Corolla
The mask is not sealing around the nose and it sounds like it's burping when it releases air.
the silicon material has been teared or the headgear velcro system hs become week and u can change the head gear and check the silicon material
Mar 16, 2011 | RTO FlexiFit 405 Nasal Mask with Headgear
There is a great deal of condensation build up in the mask and when employees bend over there is so much water it pours out the exhilation valve
This is caused to the different temperatures of the mask on the outside so it is condensing the water there is two solutions one is to get the temperature to about 15 degrees warmer on the outside or go to the half mask with the canister filter for paint professionals then the canisters will keep the mask warm enough to keep it from condensing as much. You may be able to buy a kit for adding the canster if you go to a automotive paint shop they will have a book for you to look up the one you have and see if you can retrofit the screw on canister.
Nov 26, 2009 | 3M 6100, 6200, 6300 Half-Face Reusable...
F20 Error for Kenmore HE3 Gas Dryer
make sure your vent for the dryer isn't starting to get clogged or it may have a hole in it therefore hot moist air is getting in the closet instead of outdise
Sep 07, 2009 | Dryers
How to replace main bearing in a Makita GA5000 5'' angle grinder. I removed the clip in the gear head but can't remove the gear to pull the armature. The main armature bearing in the gear head is shot.
i used to grab the armature and tap the housing off with a rubber hammer...
try tapping in opposite corners every time....
when it does fall have a cushion ready on the bench or floor to catch it...
Jul 10, 2009 | Makita GA7020 Angle Grinder
How to choose a scuba mask
"The shape of the scuba mask and the silicone skirt on the mask must conform to the shape of your face to provide you with a comfortable fit. Ensuring the silicone skirt is a high-grade, flexible silicone can help to ensure the scuba mask conforms to the shape of your face and the long life of your scuba mask. Some people are allergic to different types of rubber, if you have an allergy to rubber, be sure to choose a silicone scuba mask because silicone is hypoallergenic. Always talk to your scuba diving gear retailer about the alternatives available to you. When trying on scuba masks you will notice the different shapes of the nose pockets. The nose pocket protects and cushions your nose, helps to keep your scuba mask from fogging during a dive and helps you to maintain equalization. Ensure the size and shape of your nose pocket is comfortable; not too tight and not too large. This will improve not only the comfort of your scuba mask, but your ability to purge your mask efficiently. There are increasingly different styles of scuba mask straps on the market. You may like the factory issue strap on your scuba mask or you may want to purchase a separate strap. Scuba mask straps are available in a single strap or a double strap design. The single strap should wrap around the centre of the back of your head. The benefit of the double strap is that you can position the top strap on the upper part of your head and the bottom strap on the lower part of your head to offer extra stability and comfort. Most scuba mask straps are rubber or silicone and fasten with a post-hole belt enclosure. Newer scuba masks offer a slide-lock type enclosure, which allows you to adjust the scuba mask quickly and easily when wearing the mask. Scuba masks are constantly improving. If you wear prescription glasses or contact lenses on a daily basis you can purchase a scuba mask without having to wear your glasses or contact lenses under your mask. Many manufacturers will create custom scuba masks which include your prescription in the front lens. A good sign you have chosen the right scuba mask for your face is when the mask stays on your face comfortably without using the straps to hold it in place. You should try this simple test with each scuba mask you try on for the first time: See our choices for scuba masks 1. Place the scuba mask over your eyes and mouth ensuring the mask is in the correct position. 2. Take a quick, light breath in through your nose and immediately start to breathe through your mouth as if you are scuba diving. This will create a slight suction between the scuba mask and your face. The scuba mask should stay on your face. If you must push the scuba mask against your face, or inhale repeatedly to help the mask stay on your face, the mask is not a good fit. 3. Keep the scuba mask on your face for approximately one minute. This will help you to determine how tight the seal is and how comfortable the mask is on your face. 4. Exhale gently through your nose to release the seal on your scuba mask and remove the mask from your face. There should be no mark on your face from the scuba mask. If there is a red line around your face from the seal of the mask, the seal was too tight or the mask is not the proper size for your face. Try the test a second time. If you still have a red mark on your face after you remove the mask, you need to continue your search for a scuba mask. Remember, a good scuba mask is one that's comfortable, doesn't leak and is easy to use."
Dec 01, 2008 | Vision Mares Pure Mask
Scuba Diving & Snorkeling Logo
359 people viewed this question
Top Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Tom Chichester
Are you a Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
