Question about Scuba Diving & Snorkeling
Is it real? - Scuba Diving & Snorkeling
Posted by elizabeth on
Fahr Quad
  • 774 Answers
Yes and no. For a less ambiguous answer please specify of what you want to know the state of existence.
Posted on Mar 02, 2015
Jerry Kramer
  • 3,904 Answers
Yes...the octopus does exist.
Edit Casio FX - 9860G SD have complex equations??
Thhe Casio FX-9860G SD can solve a polynomial equation of degree 2 or 3 with REAL coefficients. If the complex MODE is set to REAL it will find the real roots. If the complex mode is set to a+ib, it will find the real and complex roots.
Apparently it will take coefficients that are real, and will give a Ma Error if any coefficient is complex.
Addendum.
The calculator CANNOT solve equations with complex coefficient. YOU can however convert the system of linear equations with ccomplex coefficients ( of the type you show) as a system of 4 linear equations in 4 unknowns; Split x into a real and an imaginary part, split y into a real and an imaginary part. Substitute Real(x)+iIm(x) for variable x in the equations; substitute Real(y)+iIm(y) for y in the two equations; do the algebra. In each of the original equations split the Real and imaginary parts. You should be able to derive 4 linear equations in unknowns Real(x), Im(x), Real(y), and Im(y).
Use the linear equation solver to obtain the solutions. Recompose x=Real(x)+iIm(x), and y=Real(y)+iIm(y)
Alternatively, after you create the system of 4 linear equations you can use the matrix utility to find Real(x), Im(x), Real(y) and Im(y) and recompose the x and y.
Mar 17, 2012 | Casio FX-9860G Graphic Calculator
Casio FX - 9860G SD have complex equations?? edit
The Casio FX-9860G SD can solve a polynomial equation of degree 2 or 3 with REAL coefficients. If the complex MODE is set to REAL it will find the real roots. If the complex mode is set to a+ib, it will find the real and complex roots.
Addendum.
Mar 17, 2012 | Casio Office Equipment & Supplies
Bibbliography of real numbers
Real Numbers are just numbers like: 1 12.38 -0.8625 3/4 ?2 1998 In fact:
Nearly any number you can think of is a Real Number
Real Numbers include: yes.gif Whole Numbers (like 1,2,3,4, etc) yes.gif Rational Numbers (like 3/4, 0.125, 0.333..., 1.1, etc ) yes.gif Irrational Numbers (like ?, ?3, etc )
Real Numbers can also be positive, negative or zero.
So ... what is NOT a Real Number? no.gif ?-1 (the square root of minus 1) is not a Real Number, it is an Imaginary Number no.gif Infinity is not a Real Number And there are also some special numbers that mathematicians play with that are not Real Numbers
Why are they called "Real" Numbers?
Because they are not Imaginary Numbers.
The Real Numbers did not have a name before Imaginary Numbers were thought of. They got called "Real" because they were not Imaginary. That is the actual answer!
The Real Number Line The Real Number Line is like an actual geometric line.
A point is chosen on the line to be the "origin", points to the right will be positive, and points to the left will be negative.
real-number-line.gif A distance is chosen to be "1", and the whole numbers can then be marked off: {1,2,3,...), and also in the negative direction: {-1,-2,-3, ...}
Any point on the line is a Real Number:
  • The numbers could be rational (like 20/9)
  • or irrational (like ?)
But you won't find Infinity, or an Imaginary Number.
Real does not mean they are in the real world blue-speech.gif They are not called "Real" because they show the value of something real.
In mathematics we like our numbers pure, if we write 0.5 we mean exactly half, but in the real world half may not be exact (try cutting an apple exactly in half).
Jul 10, 2011 | Computers & Internet
Scuba Diving & Snorkeling Logo
810 people viewed this question
Top Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Tom Chichester
Are you a Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
