20 Most Recent
Casio Calculator Graphing FX 9750GII Calculator Questions & Answers
I do not know what a range is and where to find it on a Casio FX 9750GII Calculator
In statistics, the range of 1-var a data set is the difference between the largest value and the smallest. R=Xmax-Xmin
In functions: the range of a function is the interval (or the Union of intervals) of the real line where the dependent variable takes it values.
Ex: sin(x). Whatever the value of the independent variable x, the values of the function sin(x) are in the closed interval [-1,1]. The range of the functions sin(x), and cos(x) is [-1,1].
No use of a calculator for finding the range of functions.
My Casio fx-9750GII wont dispay a table
The message dimension error usually refers to instances where two lists do not have the same dimensions (number of elements)I checked and the calculator gives condition error. Check the type of function you are creating a table for. Choose the type y=
Where is the math button on the casio fx-9750G11
It is a calculator and prqactically every button is a MATH button. It
depends on what MATH you intend to do. Put the calculator in Run/Mat
screen then press the OPTN key. You will see several tabs. Press the
function key under a TAB and explore what is offered. Go through all the
keys (F6 also) and see what the new tabs do. In general it is most helpful to read the manual that shipped with the calculator.
How do i do prime numbers on the NEWYES NY-991MS calculator and CTIFREE fx-991ES PLUS calculator?
The NEWYES NY-991MS and CTIFREE fx-991ES PLUS calculators do not have a dedicated "FACT" button like the Casio FX-83GTX. However, you can still find prime numbers on these calculators.To find prime numbers:NEWYES NY-991MS:Press the "MODE" button.Choose "PRIME" from the list of options.Enter the desired number and press "=" to check if it's prime.CTIFREE fx-991ES PLUS:Press the "MODE" button.Select "TABLE" or "TABLESET."Input a starting point and an ending point, then observe the table for prime numbers.Although the techniques may vary from those used on the Casio FX-83GTX, they prove to be effective for prime number calculations on the designated calculators.
Casio QT-6600 kitchen printer stop working.
Is there lights on, on the printer? Does it have a receipt paper roll in it?
You can do a Power Cycle of the Terminal and the Printer. Unplug the printer for the wall socket. Remove the data socket, replace the data socket making sure the connection is tight.
Disconnect the terminal from the main power, and count to 20. Plug the terminal back in.
Now go to the kitchen and plug the printer back into the mains.
The reset should fix it. The rest is in the manual, which I told you earlier today. Yes it is complicated and you may have a network switch if you have multiple terminals and possibly a computer joining everything. If you find that too complicated, call the company that sold you the unit and tell them to bring a new ticket printer with them 'just in case'. That type if ticket printer is fairly specialized, but they are common. They normally don't charge for that type of help
In the manual under Remote Printer Control.
https://totalpos.co.nz/wp-content/uploads/2020/03/QT6600-Reference-Manual.pdf
More here
https://www.google.com/search?q=Casio+QT-6600+connect+kitchen+printer
