20 Most Recent Casio FX9750GII Graphic Calculator Questions & Answers
Read the comprehensive instructions that came with it or download the instructions.
Casio FX9750GII... • Answered on Feb 09, 2021
  1. Press [AC/ON].
  2. Press [SHIFT] [MENU]
  3. Press [v] [v] [v] [v] [F1]
  4. Press [EXIT] [AC/ON]
Try out: [SIN] 45 [EXE], result should be 0.5.
Casio FX9750GII... • Answered on Jun 01, 2016
Once the matrix is created you can use the reciprocal key to get the inverse.
I hope you will not hold against me if I showed the whole porocess. (No reflexion on your or anybody's abilities to create a matrix. Just trying to be helpful to more people.)
Press Menu to display icons.
Press 1 or use Arrows to highlight Run/Mat.Press EXE
Press the F1 key to activate the Mat TAB.
While a matrix label is higlighted press F3:Dim to enter the dimensions.
Matrix must be square.
Fill her up!
Press EXE after entering the last element.
Then press EXIT to return to the Run/Mat Screen.
In Run/Mat screen press the OPTN key. Press F1 to enter the Mat identifier
followed by [ALPHA] A (if the matrix you created is stored in A)
At this point the screen displays Mat A.
Any of the continuations of the command shown below will yield the inverse matrix.
The minus sign you see in the 2nd and 3rd commands below is the change sign (-)
For the bogus 2X2 matrix I entered, the result is as follows.
Notice that even if inside the answer matrix the elements are displayed as decimals, the
values you will see at the bottom are exact fractions.
Casio FX9750GII... • Answered on Mar 10, 2016
The relational operators (=, >, <, and similar symbols) are available in two places. If you are trying to draw an inequality graphPress the Graph Menu, Press F3:TypePress F6:> to access other tabs. The 4 inequality symbols are availabe in the following screen.Press F1:>, F2:< etc. to type in the inequality sign in your inequality.If you want the relational operators for some other purpose, you can access then in the catalog of commands.Press MenuPress 1:Run>Mat to go to the main calculator screenPress [SHIFT][4] (Catalog] to open the Catalog.Scroll up or down until you reach the relational operator you want.Select it and press EXE.
Casio FX9750GII... • Answered on Sep 25, 2015
All calculator use scientific notation if the result is too small or too large. Some, like the Casio FX9750G II, offer you two Normal displays, Norm1 and Norm2 that have different limits when numbers are converted to scientific notations.Here is how to set one or the other.In Run>Mat press SHIFT MODE (Setup). Scroll down or up to reach the display line. Press F3 to select Norm1 or Norm2.647acb92-c2d8-4c4c-8ce1-1038cd750f4e.png
Casio FX9750GII... • Answered on Feb 13, 2015
What is the question. Your calculator FX-9750 GII does not have a Computer Algebra System or CAS, so you cannot factor a polynomial.If you want you can try to find the zeros of the polynomial function (the values of x when the function crosses the horizontal axis) either by solving P(x)=0 or by graphing y=P(x).Once you have the approximate roots x_1, x_2, ...,x_n, you can factor out the coefficient of the leading term (the term with the highest power) and write P(x) =a_n *G(x). here a_n is the coefficient of the leading term.G(x) can then be written as G(x)=(x-x_1)(x-x_2)*(x=x_3)...(x-x_n)and the original polynomial will beP(x)=a_n(x-x_1)(x-x_2)*...*(x-x_n)Note: Here is an example of P(x) and the corresponding G(x)P(x)=5x^3+7x^2-13x^+29P(x)=5(x^3+ (7/3)*x^2-(13/5)x+29/5)G(x)=x^3+ (7/3)*x^2-(13/5)x+29/5You should keep in mind that the roots are in general complex. Not all polynomials are factorisable in the set of Real numbers.
Casio FX9750GII... • Answered on Oct 02, 2014
Either you have an idea where the extremum (minimum/ maximum) might be (its x-value and maybe its y-value) and you set the center of the graph accordingly, or you zoom out until you locate it.Them you change the center of the graph to be about the position of the extremum. There is no ready made recipe that will work for any function. Just Trial and error. It might help calculating a few values of the function for x=0, x=-10. If the extremum happens to be within the table that the calculator generated to draw the graph, then it will be found.
Casio FX9750GII... • Answered on Sep 25, 2014
The simplest way is X1=cos(T) Y1=sin(T) Set angle unit to radians, Set the Zoom window to SQR (square), otherwise your circle will look like an ellipse.
Casio FX9750GII... • Answered on Sep 04, 2014
What is the meaning of that question. Are you doing transformations? In that case you exchange the variables, not the axes.
Casio FX9750GII... • Answered on Aug 27, 2014
Press [SHIFT][Log_ab], below the ON button. Better use the MathIO input/Output mode.
That backwards L is the fraction symbol. The FX9750 GII does nor have the Math display.
The tangent of 40 radians is a negative number.
Casio FX9750GII... • Answered on Jun 15, 2014
Casio FX9750GII Graphic Calculator Logo
200 questions posted
Top Casio Office Equipment & Supplies Experts
k24674
matt
matt
ADMIN Canada
ADMIN Canada
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Casio Office Equipment & Supplies
Most Popular Question
cursor annoying little horizontal line
  • Office Equipment & Supplies
