20 Most Recent Felker FRS-38 Tile, Marble & Granite Rail Saw Questions & Answers
2answers
Where can I buy high-quality bathroom tiles in London?
If you want to buy High-Quality Tiles then I like to recommend Ceramics & Beyond the leading tiles manufacturer and suppliers. Handmade Tiles Manufacturers in Delhi Hand Printed Tiles India
12/3/2018 12:15:35 PM • Felker FRS-38... • Answered on Dec 03, 2018
Why does tile veer off?
If you have a bridge saw. The blade and motor may not be parallel with the rails the motor travels on.
4/18/2014 6:00:26 AM • Felker FRS-38... • Answered on Apr 18, 2014
2answers
I have a Felker Tile Master saw and was told there is a button to hold to change out the blade. I assume this locks the motor. I can't seem to find it. Need help!
It's called the shaft lock. I attached a pic of a Felker manual diagram. Your saw will be the same or similar. 26223798-03a1ksxemixbizoxkbkm3skx-4-0.jpg
6/23/2016 1:59:40 AM • Felker Saws • Answered on Jun 23, 2016
Water pump not working correctly
Probably need a new pump or water tube is clogged. You can try to blow out the pump and water tube with air to clean it internally. You can buy a new pump on line at Contractors Direct for about $50.
3/31/2015 5:44:29 PM • Felker Saws • Answered on Mar 31, 2015
0answers
2answers
Why my Makita disc cutter has spark wont start
If the fuel in it is 2 or more months old dump it out and put in fresh fuel and try statring. Also try try a squirt of starting fluid into the carb. If it fires on it you may need to do this a few times to pull the old fuel in the lines through till the fresh fuel can get to the carb.
4/10/2024 4:13:02 PM • Saws • Answered on Apr 10, 2024
I'm looking for a user manual for a Toolex bandsaw model SW-1404
closes I could find.copy and paste.https://www.carbatec.com.au/documents/manuals/Carbatec/Bandsaws/SW-1401-manual.pdf
3/23/2024 3:57:46 PM • Saws • Answered on Mar 23, 2024
Black & Decker 9443 10 Inch Band Saw. I need a user manual for b & d 9443 10" band saw please.
Question edited for clarity, 'make model (what it is)', in full. No manual, just parts. Try black and Decker direct. https://www.google.com/search?q=black+and+decker+9443+bandsaw+manual https://support.blackanddecker.com/hc/en-us/p/all_locations ..
3/19/2024 1:22:02 AM • Saws • Answered on Mar 19, 2024
2answers
How do I remove the guard assembly on a Dewalt DW936 portable circular saw
@Brian AndersonIt is better to write a new question rather than tagging an unsolved question from 10 years ago. It is now stuck on the Homepage as 'Pinned' and still showing Unsolved! :>Dhttps://www.google.com/search?q=+Dewalt+DW936+remove+the+guard+assembly..
3/15/2024 11:43:33 AM • Saws • Answered on Mar 15, 2024
How do I put the blades on twincut power saw + its different from any other grinder or cut off tool that I have used
https://www.manualslib.com/manual/1823573/Twin-Cut-Power-SawPlus.html?page=17#manual
2/14/2024 2:39:32 PM • Saws • Answered on Feb 14, 2024
Altendorf WA80 Sliding Table Saw. It shows an error code E.H1. What does it mean please?
Question edited for clarity, 'make model (what is is)'. Question moved from Washing Machines category. E1 Error, but not E.H1. https://www.google.com/search?q=Altendorf+WA80+error+code+EH1 Manual Errors and Troubleshooting. https://www.manualslib.com/manual/1583371/Altendorf-Wa-80.html?page=45 ..
2/13/2024 5:52:08 AM • Saws • Answered on Feb 13, 2024
Need manual for power kraft model 84-6460 tranist
How to use model number 84-6460
2/9/2024 2:51:39 AM • Saws • Answered on Feb 09, 2024
My wet tile saw keeps tripping the breaker despite new capacitor it is still not staying running
if keeps tripping breaker use multi to check plug wire or motor short
1/12/2024 8:20:54 PM • Saws • Answered on Jan 12, 2024
Amada band saw ha 250 repair manual
1/12/2024 2:50:24 AM • Saws • Answered on Jan 12, 2024
Felker FRS-38 Tile, Marble & Granite Rail Saw Logo
3 questions posted
Top Felker Saws Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Felker Saw Expert? Answer questions, earn points and help others
View Most Popular
Felker Saws
  • Felker Saws
Most Popular Question
buy high quality bathroom tiles in
  • Saws
