20 Most Recent Kohler OHC 16, 18 HP Service Manual TP-2480 Questions & Answers
Why is alarm kohler engine Error code 0094 18
Please see; https://www.fixya.com/support/t25551059-kohler_generator_engine_fault_code_0094
4/20/2024 7:29:35 AM • Kohler... • Answered on Apr 20, 2024
How to wire a Kohler generator starter
8/5/2023 12:31:54 AM • Kohler... • Answered on Aug 05, 2023
My Kohler 35RZ generator Auxiliary Faults on startup after a rain storm. It Otherwise starts right up and runs. .
That is the specific use of WD40. Spray it when it is warm and the kerosene will evaporate and leave the waxy protective coating behind.
1/25/2023 11:41:58 PM • Kohler... • Answered on Jan 25, 2023
20 kw RESA Kohler Generator " locked rotor " problem where do I start. New battery as been installed
You need to repair your locked rotor then it will work
12/19/2022 7:51:01 AM • Kohler... • Answered on Dec 19, 2022
Kohler 14resa gen just stopped running no spark, changed out ign coils still no spark.
not car moved yah lost the users manual??? in it is the schematic, and on said schematic is what kills spark dead. 1: oil switch bad. 2:kill switch bad. 3: wires too those cut or shorted. it's all there to read, ask maker for the lost manual
12/11/2022 6:48:59 PM • Kohler... • Answered on Dec 11, 2022
I have a Kohler Model 4.5 CKM 21-rv How do you check the voltage regulator # C 239311
Don't think you can check the avr it's self (capacitors you can) there are continuity tests you can do to the windings of the generator to determine a fault with that if that all checks out ok the avr is at fault
11/12/2022 8:28:44 PM • Kohler... • Answered on Nov 12, 2022
I have a generator 55kv hi volt 460 what is the problem
depending on the machine Could be the Rpm to high
11/12/2022 8:20:43 PM • Kohler... • Answered on Nov 12, 2022
2answers
What is the fix for a locked Rotor code on my Kohler 14 RESA generator?
Hi, if possible please check your speed sensors within your generator to make sure each is still functioning properly. Otherwise, you might have to replace the sensors before the code goes away. Thank you.
10/20/2022 11:21:08 PM • Kohler... • Answered on Oct 20, 2022
2answers
Aux fault on Kohler generator 5ekd says 17.0 fault check engine
More supports or if you consider diesel generator set in furture, please contact [email protected], or visit at: www.dieselgeneratortech.com
10/12/2022 3:12:06 PM • Kohler... • Answered on Oct 12, 2022
Kohler 5ecd generator giving high battery voltage alarm
Fault code is displayed if the engine starting battery voltage rises above 16 VDC for a 12 VDC system or above 30 VDC for a 24 VDC system for more than 2 seconds when the engine is not running. This fault condition does not inhibit engine starting. The fault condition clears when the battery voltage returns to a voltage within the limits for more than 2 seconds Check the battery rating and condition.
10/12/2022 2:42:21 PM • Kohler... • Answered on Oct 12, 2022
I have a kohler 5E generator has SPARK only on one side
Kohler 5e Marine or mobile/Generator?????? working on this lacking a meter and manual. ? working blind I call it. not good that ever. call for help: it has 2 coils, 2 sparkplugs 2 HV wires to fail, (1 of them) and 2coil igniter we use and ohmeter to the bad coil. primary is of coil (ignitor end) is about 5 to 12ohms. (infinity bad) secondary coil is high ohms 1000 to 10000, par, infinty bad. the HV lead is used to measure secondary to coil core metal the HV lead can fail too. making coil useless. and last a bad ignitor , the 2 coils are same P/N so can be swapped and if failure move to other plug, bingo for bad plug , otherwise bad ingnitor box.
9/20/2022 2:15:49 PM • Kohler... • Answered on Sep 20, 2022
Kohler House Generator powers up when our electricity goes out but then powers right back down?
That is an engine running issue, not a battery issue. :>D The first thing to check would be fuel supply. Can you start up manually and keep it running. If you can, it is the contactor that senses your loss of mains power and switches the generator on. It is not maintaining the connection, or is is misdiagnosing the power from the generator as power from the mains.
8/31/2022 11:40:03 PM • Kohler... • Answered on Aug 31, 2022
2answers
Kohler Confidant 5 Generator. I put in new spark plugs and gas line. It runs but will not put power in motor home. How to change or check brushes?
Question edited for clarity. Two duplicate Questions deleted and amalgamated into one question. Refresh the page to see your question published. Help in the link, it is common. https://www.google.com/search?q=Kohler+Confidant+5+Generator%2C+no+power+output ..
8/31/2022 7:10:22 AM • Kohler... • Answered on Aug 31, 2022
2answers
What is maximum that discharge water should be for a gasoline Kohler marine generator 7.5
the water pump decides that and not told that. maker nor model 7.5 means kilo watt, KW. of energy;. for gen or 7500watts a pump less that that can push a lot of water GPM gallons per minute,but have not idea what you are doing.
8/16/2022 11:07:03 PM • Kohler... • Answered on Aug 16, 2022
2answers
I have a 18RESA Kohler Generator that I keep getting a locked Rotor code warning. I clear it and then try to restart and it comes up again. The battery appears to be good.
Locked Rotor is reported as an overcrank fault "OC".
You first need to verify the engine fails to crank, which is likely a starter motor or start circuit failure.
If the engine cranks three separate times and then the OC fault occurs, it simply means the engine did not run... more likely a fuel issue.
But either can be caused by numerous reasons.
2/18/2022 8:10:05 PM • Kohler... • Answered on Feb 18, 2022
Kohler k-1559 steam generator. How to decode the LED's on control board?
https://data2.manualslib.com/pdf7/158/15786/1578591-kohler/k5533.pdf?7488b1b152af3ddb1ced5fb2a0565ea0 This is about as close as I can come to offering the info you require. You could try more modles at the manual site or even try Kohler support. https://www.us.kohler.com/us/
10/5/2021 7:04:28 PM • Kohler... • Answered on Oct 05, 2021
What is kohler generator engine fault code 0094-01 means?
Koehler gen set while running automatically off and not showing any codes
9/28/2021 5:52:50 AM • Kohler... • Answered on Sep 28, 2021
Kohler OHC 16, 18 HP Service Manual TP-2480 Logo
2 questions posted
Top Kohler Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kohler Electrical Supplies
Most Popular Question
cylinder head torque specs 23 horse
  • Electrical Supplies
