20 Most Recent Kohler CH25 PA-CH730-0040 Command Gasoline Engine Questions & Answers
You will have to hold the flywheel for removing the clutch. It may require removing the blower housing. I use an impact wrench which loosens the bolt w/o holding the flywheel. It's 99% a regular bolt (turn ccw to remove) since left hand threads cost more to buy the bolt and tap the hole and small engine stuff is made as cheaply as possible.
Kohler CH25... • Answered on Jan 22, 2018
Does your unit have a low oil kill sensor if it does the unit won't start if the oil is low also if the sensor is bad that will kill the power. I do know if this may be your problem but check the oil level. good luck.
Kohler CH25... • Answered on Sep 03, 2017
Not likely carb because both cylinders would act the same; not likely coil because both cylinders fire together, however could be wire/boot from coil, plug or low compression/valve adjustment. Premium fuel works miracles on small engines; try a couple of gallons, it will increase horsepower. Check compression and compare to good cylinder, if close, suspect plug or boot. If compression low, hope that valve adjustment will normalize. Good Luck
Kohler CH25... • Answered on Feb 16, 2016
I believe that is an overhead valve engine. that the valve cover off and turn the crank until both Intake and exhaust valves are closed. That is TDC
Kohler CH25... • Answered on Jul 06, 2015
I use 150 ft lbs on my racing 2-cycle engines, tighten in a star pattern.
Kohler CH25... • Answered on Jul 01, 2015
turn the crank shaft and watch the relationship between the piston position and the cam followers. As the piston nears top dead centre you will see the exhaust cam follower start to move down and the inlet cam follower start to rise up. This will create a rocking motion of the cam followers at top dead centre. This is known as valve overlap assemble the motor in this position. Ensure the valve clearance is backed right off Turn the crank shaft one full revolution and you now have the compression stroke . This places the piston again on TDC and it is at this position you adjust the valve clearance. Check that clearance for the tappets as most engines run .010" and .012"tappet clearance. If the head is fitted last place the push rods in the cam followers if you cannot see the cam followers and it does the same job. When the top of the push rods reach the overlap situation it is just an extension of the cam followers.
Kohler CH25... • Answered on Jun 23, 2015
Make sure you have good compression. Sounds like you have blow-by. Crankcase vents into the air box.
Kohler CH25... • Answered on Mar 07, 2015
When you remove the battery it will break the circuit and die and if your battery dosen't have at least 5v in it it won't charge and you will have to replace it.
Kohler CH25... • Answered on Mar 04, 2015
Bad plug, ignition wire, valve clearance, or valve damage, vacuum leak at manifold. Timing cam off / damaged
Kohler CH25... • Answered on Mar 02, 2015
I believe the ignition timing is fixed on that motor, via a pickup on the crankshaft
Kohler CH25... • Answered on Mar 01, 2015
It seems like you have the model number in your question. Clarify what you're looking for and I can help you. Are you looking where to find these numbers on your engine and you just posted some random model number or do you want to know the model number definition, like what letter and number means what?
Kohler CH25... • Answered on Feb 13, 2015
look down inside air cleaner before starting next time , if theres more than a finger full of motor oil in there then your head gaskets are going
Kohler CH25... • Answered on Jan 30, 2015
engines that dont run smooth are most allways a problem with fuel , clean/replace all parts in fuel pathway , including the carb
i bet its on a machine that sits outside a lot , if you remove top fan cover i'll further bet you see a build up of fuzzy lint / grass right by ign coil , your coil is being overheated by this "Stuff" and now has gone intermitant , your gonna need to replace it , see my video on youtube on how to do this , i did a video of this a few years back because i got so many requests for this from folks , it is quite easy even my 12 year old son (folowing my method) has done one before with no problems
now the kohler v-twin does have a bit of a problem with camshafts in this size range , your gonna need to remove valve cover on head side that you suspect is bad , verify that valves move in order (one at a time) as you turn over by hand with spark plugs removed (both sides)
this allmost allwways means a bad head gasket if this happens , and most head gasket failures are from overheated blocks meaning a warped head face but on rare occasions it could allso be a bad valve stem seal
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
296 questions posted
Top Kohler Electrical Supplies Experts
Sheldon Dedek
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kohler Electrical Supplies
Most Popular Question
engine wont start key turn number times
  • Electrical Supplies
