20 Most Recent
Wahl 9918-600 Beard Trimmer Questions & Answers
How do I split the case of my Wahl 9916C beard
Bottom side (black on mine) has a finger grove section that comes off with a small flat blade screw driver used to pry up, 4 tabs, one on each corner (Exposes 2 screws). Need a sauder (spelling not my thing) gun to remove and batteries are 2 ea 1.2 v (looks between AA & AAA size). I'm just going to just buy another unit. Good luck!
How Do I set up a WAHL battery trimmer uo
The covers are very tight if it is the one in the photo. Push in on the black cover and slid it towards the bottom. I think the clip that is giving you the problem is at the top end of that black cover.
How do i put back the blades on a wahl 9918C beard trimmer
You connect the blades together with the plastic part the correct way through the top of the small moving blade. The plastic part becomes a guide to keep the 2 blades running straight and true. Then engage the plastic part into the motor cam shaft and the 2 tension springs at the same time and wriggle it onto the screw hole posts and fit & tighten the screws. Lubricate and you're done.
