I took off the blades to clean out the hair and now i cannot replace them
You connect the blades together with the plastic part the correct way through the top of the small moving blade. The plastic part becomes a guide to keep the 2 blades running straight and true. Then engage the plastic part into the motor cam shaft and the 2 tension springs at the same time and wriggle it onto the screw hole posts and fit & tighten the screws. Lubricate and you're done.
SOURCE: re-assembling my Wahl Beard Trimmer Model # 9918C
Turn the trimmer off. Put your thumb under the teeth of the attachment. Push Up. The attachment should snap off. Replace the beard trimmer in the slot. Hope this helps.
SOURCE: How do I split the case of my Wahl 9916C beard
Bottom side (black on mine) has a finger grove section that comes off with a small flat blade screw driver used to pry up, 4 tabs, one on each corner (Exposes 2 screws). Need a sauder (spelling not my thing) gun to remove and batteries are 2 ea 1.2 v (looks between AA & AAA size). I'm just going to just buy another unit. Good luck!
SOURCE: HOW DO I PUT MY WAHL HAIR TRIMMER BLADES BACK TOGETHER
well the smaller blade sits on plastic piece that is coming out of the clipper, having the inside of blade towards you. then larger blade ,the inside of that faces smaller blade,and align them to where you can see smaller teeth thru larger ones put screw back in and tighten. then oil them.
SOURCE: On a Wahl Beard Trimmer
The button info requested is almost 2 years old, but on my trimmer the button to the left of the power swt on the side is to lock the trimmer blade in the front or rear position. It is kinda weak and you can still move the blade if you push it. (I do seem to have the same one shown in the picture here.)
Later!
The Shadow
