20 Most Recent Wahl 8550 Questions & Answers
I had the same problem and I eventually figured it out. The blade assembly has to be reassembled first then snapped back into place.
1. the bottom part has a little "nub" that the screws attach to
2. the second part is the thin piece of metal with a ridge
3. the white plastic thing, make sure the ridges are sandwiched together
4. the small blade, the blades must face each other
5. the large blade
use the 2 screws to hold the assembly together, once assembled it snaps into place on the clipper. See attached picture for how it should look once assembled.
It's STUPID that this is missing from the instruction guide that comes with the clippers.
Wahl 8550 | Answered on Apr 09, 2020
Mannys-sharpening.com is a Wahl Dealer they all parts for Wahl email them at [email protected]
Wahl 8550 | Answered on Jul 08, 2015
the thick racket sit on top of the lil gold bracket
Wahl 8550 | Answered on Sep 23, 2014
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Tried the above solutions but it all keeps falling apart. It's a wahl pro series rechargeable. There are two screws, large blade, small blade, white plastic part and a silver bracket that seems to slide on the white plastic part. What goes in first? How do I assemble it? How do blades match? Do the grooves on large blade fit into small blade? Help, I can't reassemble it. Thanks in advance! Pam
Wahl 8550 | Answered on Mar 31, 2014
How did you get it apart? I don't want to break the case and can't get it to release at the front of the unit.
Try Wahl http://www.wahlglobal.com/united-kingdom/ if you don't have any luck give us a call and we can talk you through it.
Wahl 8550 | Answered on Mar 24, 2014
how do i reassemble the wahl pro series pet groomer
Wahl 8550 | Answered on Mar 02, 2012
Hello there, the only place you can get replacement wahl chargers are from their service centers which are spread out around the US. Here is a Link to all their animal equipment service centers which are across the US. Also you can check the user manual and get the charger specifications from there walk into any electronics store and have any adapter with the same specifications given to you to replace the charger. This should cost you less money and time.
Hope this solution has been helpful?
Thank you for visiting FixYa.
Wahl 8550 | Answered on Aug 13, 2011
Wahl 8550 Logo
45 questions posted
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Falling star
NOEL
NOEL
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Wahl Health & Beauty
Most Popular Question
took wahl clippers apart clean
  • Health & Beauty
