20 Most Recent Dacor Preference SGM304SS Gas Cooktop Questions & Answers
PGM304-1S/NG Blue light indicator (DACOR
The bulb can be purchased and repalced as an individual item but as expected you'd need to remove the cooker top to access it.
Link below for one of many site where a replacement bulb can be purchased.
http://www.appliancepartspros.com/Appliance-Parts/dacor-light-indicator-item-number-ap3395457.aspx?pn_=62036
If you need any further assistance then just ask.
7/23/2011 9:14:34 PM • Dacor Preference... • Answered on Jul 23, 2011
I have a Dacor PGM 365 5 burner cooktop. Power burner igniter continues to spark when pot is on burner. When I remove pot igniter stops sparking. Thoughts?
The only thing I can think of is the the igniter has some faulty insulation and the pot is completing the circuit, or the pot is pressing something. They do have an igniter service kit. https://www.dacorparts.com/content/DacorLookups/PGM365-1.pdf ..
1/15/2024 9:35:14 PM • Dacor Cooktops • Answered on Jan 15, 2024
Dacor Epicure. ESG366SCH. 36 Inch Gas Cooktop. How do I access the interior of the cooktop to replace the igniter wire? Model ESG366SCH
Question edited to add maker. Question moved to correct category. Dacor only shows the parts layout. https://www.guaranteedparts.com/picture_library/Dacor/Cooktops/PM_ESG_051410.pdf Normally, you remove burners and shrouds and then look for screws at the front that secure the top panel. When you lift that up, the ignitor and wires are visible. https://www.google.com/search?q=Dacor+Epicure.+ESG366SCH+replace+igniter+leads ..
12/30/2021 5:50:17 PM • Dacor Cooktops • Answered on Dec 30, 2021
Euro kera
THINGS TO CHECK: the broil element is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms The bake element is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter.( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms The oven safety valve (also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter. I offer free advicebcuzGod is so good! Surface burners are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals. On modern electronic control ranges,the oven temperature sensor is the part thatregulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meterbut will need to know the correctresistance of the sensor at room temperature. Remove power from the appliance before performing this test. The infinite switch on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check foroverheated wires or faulty terminals first.Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
  1. If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons.(Locate the suspect switch for testing. Label all wires and terminals before disconnecting. A close up digital photo may be helpful.
  1. On the burner control switch the terminal labeled "P" leads to the burner indicator light. The terminals labeled "H1" and "H2" lead to the burner element and the terminals labeled "L1" and "L2" (sometimes "N1" and "N2") are the power supply wires.
  1. Set yourmultimeterto ohms setting x1. Turn the burner control to the highest temperature setting. Place one probe on pin "L1" and the second probe on pin "H1". The resistance measurement should be very low, zero to twenty ohms. If the test shows high or infinite resistance, the burner switch is defective.
  1. Repeat the step above for the terminals "L2" and "H2".
  1. If the control passes that test, turn the temperature setting to about the middle of the range and repeat the previous two steps. This will test for an intermittent problem with the switch. If the test does not show continuity with very low resistance, the switch should be replaced.
  1. With the switch turned to the "Off" position, the resistance on each of the pairs of terminals tested above should now show no continuity or a reading of infinite resistance.
  1. A test for continuity between "P" and "L1" when the burner control switch is on should show continuity. The light should be on whenever the control is turned on. If your test shows continuity, but the light does not operate, it is likely the bulb has failed.
If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. ) Most modern ovens usean electronic control board to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced. The oven burner igniter commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter.If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve.This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced. http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start/ https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
3/17/2020 6:56:31 AM • Dacor Cooktops • Answered on Mar 17, 2020
Dacor cooktop- won't heat
If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. ) Most modern ovens usean electronic control board to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced. The oven burner igniter commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter.If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve.This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced. http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start/ https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on- element burner 0-undefined-undefined-0_0.jpg element burner top element-testing.2-undefined-undefined-2.gif element bake broil connect -wires-undefined-undefined-5.gif element test bake broil with meter-undefined-undefined-9.jpg element removal repair electric oven-undefined-undefined-14.gif
3/17/2020 6:23:10 AM • Dacor Cooktops • Answered on Mar 17, 2020
Gas burner continues clicking after on and flame active.
many ovens are made to click like that and nothing is wrong with burner oven, its a safety measure to let you know gas is on or escaping. I f you turn the knob bac or forward a little bit it will go off and flame will still burn. Other words you may have a dirty spark igniter , see pics infinite switchs stove-undefined-undefined-0.jpg ignitor element burner cap connection-undefined-undefined-2.jpg ignitor damagedsparkignitor-undefined-undefined-5.jpg ignitor gas spark ignitor-undefined-undefined-9.jpg igniter spark clean ur ignitor-undefined-undefined-14.jpg
3/17/2020 3:59:47 AM • Dacor Cooktops • Answered on Mar 17, 2020
2answers
Dacor gas cooktop:boiled over milk & the click click of the starter began even tho eye was on. After cleaning mess I get the click click of the starter & the eye lights but starter doesn't turn off.
Extensively clean the ignitor and any passages that the gas flows through. Take it off and disassemble it if necessary, just get it clean and all will be well! ab8e3016-f29b-4875-b509-f9ddeaba1e71-jueqayu11ntuimxhnbiipgvb-3-67.jpeg
4/11/2019 9:45:58 AM • Dacor Cooktops • Answered on Apr 11, 2019
Manual for dacor gas cook top serial number M-B-06020706 model number PGM304-1S/LP/H
Try Dacor's web site always unplug electricity before attempting to repair on any electrical appliance
10/2/2017 1:05:05 PM • Dacor Cooktops • Answered on Oct 02, 2017
Dacor cooktop igniter clicks but burner does not ignite. This is true for all burners. after repeated attempts the burners will start - What can I try?
Take a hairpin or a toothpick and clean the hole near the igniter so that the maximum amount of gas can flow to the spark is what I would try.
12/29/2016 5:06:47 PM • Dacor Cooktops • Answered on Dec 29, 2016
My Dacor PGM365-01 main burner continues to spark after I place a pot or pan over it. I just replaced the spark module - still happening. Valve? Micro-switch? Clean the burner?
What is your altitude?I have the same problem and was told by Dacor that I should have the high altitude version. I'm at 5000'
5/28/2016 11:32:37 PM • Dacor Cooktops • Answered on May 28, 2016
0answers
Would like to pick-up appliance part local Los Angeles,CA.
http://www.dacor.com/customer-care/locate-a-servicer.aspx Paul go with the authorised dealers from the link above put in your post code and search
9/16/2014 5:46:41 PM • Dacor Cooktops • Answered on Sep 16, 2014
Dacor Preference SGM304SS Gas Cooktop Logo
Popular Tags
2 questions posted
Top Dacor Cooktops Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Dacor Cooktops
  • Dacor Cooktops
Most Popular Question
pgm304 1s ng blue light indicator dacor
  • Cooktops
