SOURCE: Dacor Cooktop gas conversion
Where did you purchase the kit? Can you name the store with number or list the website? Also the part number information. Thanks
SOURCE: Dacor pgm 365 lp to naural gas
Yes by a licensed person so as not to break any local laws or Kill You,
LPg typically delivers at a higher psi than natural gas, and the propane content requires more combustion air than the methane butane mix of natural gas,
methane CH4 needs 2 oxygen (O2) to make CO2 +2 H20
Propane C4H10 needs 7.5 (02) 4 CO2 5 H2O
the nozzle injecting the LPg has small diameter, The Gas certified plumber can remove the nozzle(s) and replace them with larger diameter Natural gas ones for a small price, most manufacturers make both, its a simple job
Cant stress - Gas Certified plumber/tradesman - strongly enough, one explosion will ruin your whole day
Check this link for the steps:
http://www.skymarkinternational.com/images/resources/38.pdf
Hope that helps.......
SOURCE: Converting Dacor ERD30S06CH/LP/H to Natural Gas
I know they won't convert gas water heaters but I didn't know they were afraid of stoves. See if your gas company will help. Sometimes they can drill out the orfices. Some of the older repair people still remember how to do this. The orfice for natural gas is larger as the pressure is a lot less. The gas pressure regulator will also need to be replaced. This can be done with a generic part.
SOURCE: SGM464EM cook top valve rplacement
you have to go in from the top ,,, take off burner, knobs and the screws holding top and raise to get to valves / larry
