20 Most Recent Koolatron (059586509889) Beverage Cooler Questions & Answers
I have a kolatorn ec-23and the fan doesn't run
does the compressor run? if the fan is not running then it may need to be replaced
6/4/2014 3:59:02 AM • Koolatron... • Answered on Jun 04, 2014
Koolatron mini fridge quit working
That clicking is probably a relay. It needs professional diagnosis. If it is small you can just take it to a refrigeration engineer and save the call out charge.
10/11/2023 7:05:13 PM • Koolatron... • Answered on Oct 11, 2023
Can I fix my koolarton cooler?
If your Koolatron cooler is not cooling down, even though the fan is working, there may be a problem with the compressor or the refrigerant. The compressor is a critical component of the cooling system, as it is responsible for compressing and circulating the refrigerant that absorbs heat from the air inside the cooler. If the compressor is faulty or damaged, it may not be able to compress the refrigerant properly, resulting in poor cooling performance. The refrigerant is a chemical substance that absorbs heat from the air inside the cooler and carries it to the compressor, where it is compressed and released. If the refrigerant level is low, the cooler may not be able to absorb enough heat to cool the air effectively. To fix this problem, you will need to diagnose and repair the faulty component. This may require the assistance of a qualified repair technician, as repairing a cooler's cooling system can be complex and hazardous.
12/10/2022 10:38:47 AM • Koolatron... • Answered on Dec 10, 2022
Koolatron 6 bottle wine cellar is beeping and temperature is flashing
The only way to make it stop is to unplug it. And to make it stop permanently is to take it to a recycling center and wave bye bye to it. :(
11/5/2022 3:36:11 PM • Koolatron... • Answered on Nov 05, 2022
My Koolatron mini Coca-Cola fridge has a flashing green light instead of the normal solid one and the fan isn't running. How do I fix this?
Hi, this sounds like hardware damage. You might want to setup an appointment with your local geeksquad to have the fix the issue for you. Or you can call koolatron and request the fix. Doing internal harward repair on your own could be a dangerous task, so that's why I mad my suggestion. Thank you.
9/30/2022 1:43:14 AM • Koolatron... • Answered on Sep 30, 2022
I have a koolatron cvf18 inside fan quit working where i find a replacement
Direct from Koolatron
RETRO VENDING FRIDGE thermoelectric cooler ... - Koolatron
https://www.koolatron.com > CVF18G-manual
PDF replacement parts, please telephone the following numbers ... CVF18-G. Please Read These Instructions Carefully Before Use! S.V.P., lire ... For long periods of storage, a small container of baking soda or charcoal, placed inside, will eliminate.
4/10/2021 10:09:32 PM • Koolatron... • Answered on Apr 10, 2021
Koolatron P34 schematic needed
Request the wiring diagram (not a schematic) directly from Koolatron.
12/8/2020 3:54:18 PM • Koolatron... • Answered on Dec 08, 2020
My koolatron does not get cold replaced the motor run but still does not get cold
Did you regas unit after motor replacement?
9/17/2019 10:25:45 AM • Koolatron... • Answered on Sep 17, 2019
I have a koolatron kcr40b the fan runs but does not cool, is there an easy repair?
Is the compressor running?
1/5/2019 8:41:42 PM • Koolatron... • Answered on Jan 05, 2019
My Koolatron WC18 is brand new and only heats! does not cool...??
Take it back. It’s designed to cool, not heat.
12/9/2018 8:44:49 PM • Koolatron... • Answered on Dec 09, 2018
My koolatron wc18 is not cooling the lower section but works for the top ??? I have replaced the fan and verified that both fans are working on the lower section . Any further ideas
check the thermistors ..Check ur cold control thermostat, ur thermistors in both fridge and freezer ( they should be checked for both ohms and for amount of current being put out as per ur model ), ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage. Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. FAN check to see if it is operating or restricted A fan that is not blowing or restricted will not circulate the cold air properly. Often, the first thing that folks do when their refrigerator starts to feel warm is turn both controls on the coldest settings.This is exactly the WRONG thing to do.Turning the cold control to the coldest settingwillkeep the compressor running longer and make lots of cold air. But turning the air door to the coldest settingclosesthe airway to the food section. Lots of cold air is made, but most of it stays in the freezer section, and the food section actually getswarmer. defrost terminator thermistordefrostterminator-do14a2fbasaynlmbumjtahuz-1-0.jpg door seals bad door seals-do14a2fbasaynlmbumjtahuz-1-2.jpg thermistor badgoodthermistor-do14a2fbasaynlmbumjtahuz-1-5.png
12/8/2018 11:31:52 PM • Koolatron... • Answered on Dec 08, 2018
Lost cord for my koolatron
8/20/2018 11:11:58 PM • Koolatron... • Answered on Aug 20, 2018
I need a QILI POWER SUPPLY MODEL QL-08011-B1205000F---12V 5000mA for my coco cola vending fridge. Anyone know wher to find one? I called factory, they arn't making them anymore.
Any power supply that has the output you indicated will do the trick provided it fits into the allotted space.
8/7/2018 2:34:46 AM • Koolatron... • Answered on Aug 07, 2018
0answers
Koolatron (059586509889) Beverage Cooler Logo
4 questions posted
Top Koolatron Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
ADMIN Eric
ADMIN Eric
Are you a Koolatron Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Koolatron Refrigerators
Most Popular Question
kolatorn ec 23and fan doesnt run
  • Refrigerators
