20 Most Recent
Koolatron (785169015699) Questions & Answers
Vending machine issues
Only the fan at the compressor turns on and off with the compressor cycle. The evaporator fan runs steady to maintain air circulation and temperature balance and to affect evaporator defrost in the off cycle. Sometimes the condenser fan will run continuously to assist in the evaporation of condensed moisture from the evaporator drainage.
2/19/2021 2:17:26 PM •
Koolatron...
Answered
on Feb 19, 2021
WONT RUN
compressor is not starting . you might try a 3 in 1 booster pack.
5/21/2014 4:31:37 PM •
Koolatron...
Answered
on May 21, 2014
EC-23 machine, fans seem to
If the fan is running then the problem is most likely the Peltier junction cooler.It will have to be replaced.
1/23/2012 1:37:07 AM •
Koolatron...
Answered
on Jan 23, 2012
When I plug in my koolatron EC-23 the power LED
The noises are a sign that the power source is overstressed by a short and it goes in and out of protected mode. Before replacing it you must find out if the short is on one of the other components or the psu itself: disconnect it from your device and start it alone - if it still makes the noise or the voltages on its outputs aren't ok then it's definitely dead.
Yes, it can be replaces with one, but you will have to modify the connectors and the wiring.
2/22/2011 8:18:19 AM •
Koolatron...
Answered
on Feb 22, 2011
My koolatron mini vending fridge
hello. these are neat little fridges arent they. your situation is normal and you can let it leak as it is or you can follow the maintenance routine outlined herein:
Periodically you will need to remove, clean and dry the tray where the cans fall onto when dispensed. This will require more frequent attention in humid conditions. High humidity will also cause condensation inside the unit that should be wiped up with a dry cloth. When cleaning, turn off the power switch and disconnect the power cord. Vacuum out the ventilation grills on the back of the unit. Use only a damp warm cloth and a mild detergent for cleaning. Avoid the use of harsh cleaning agents and solvents. If storing the Vending Machine please switch off the power, disconnect the power cord, then clean and dry it thoroughly.
10/11/2009 2:15:50 AM •
Koolatron...
Answered
on Oct 11, 2009
