20 Most Recent
Powerware Series 9 9150 UPS System Questions & Answers
Contineous beep even though we
It not your battery problem . Your overload protection is on to reset this protection. You can't reset the protection to give help from service expert.
UPS in bypass with alarm code 2 short beeps and 5 long beeps.
You can view the manual here: http://powerquality.eaton.com/Products-services/legacy/9150-info.asp
You can also contact the Eaton service department as they'll know this UPS better than anybody. They acquired Powerware years ago and kept the service personnel.
Toll Free: 1 800 843 9433
International: +1 919 871 1800
E-mail:
[email protected]
9150
Here is the documentation page for the 9150: http://powerquality.eaton.com/Products-services/legacy/9150-info.asp
The 9150 had a couple of different Extended Battery Cabinets for longer runtimes but the 9150 was discontinued so I suggest you reach out to Eaton's service department.
1 800 843 9433
E-mail:
[email protected]
What are the dimensions and weight of the
Here is the documentation page for the 9150: http://powerquality.eaton.com/Products-services/legacy/9150-info.asp Looks like 28 inches high x 16 inches wide x 29.5 inches deep. 510 pounds (231kg). If you need further support, you can call Eaton (Powerware was bought by Eaton)
1 800 843 9433
E-mail:
[email protected]
Alarm mode question
sounds like battery failed, check the connections and clean them, then try it again. see if the battery is ok, check voltage, and shake the battery, if you hear little objects rattle inside, it is bad. i hope this is helpful,good luck,glen also consider the unit could be shot.
