You shouldn't need a code to reset the handset, but the base requires a PIN (
Default PIN is "0000"). I have typed the instructions below, but here is a link to the online PDF:
http://dl.owneriq.net/5/5d7cdc19-660a-8934-7d52-e5205df74c27.pdfHandset:
- Menu -> Settings ->Handset -> Reset Handset
- OK - press the control key to confirm
- End Call Button - Long Press (Idle Status)
This will reset individual settings & changes made by you. It will not affect the directory, calls list, SMS lists, the handset registration to the base and stored pictures or ringer melodies.
Base:
- Menu -> Settings -> Base -> Base Reset
- Enter the system PIN (Default PIN "0000" or the PIN you created)
- OK - Press the control key to confirm
If you already changed the system PIN to one of your own you will need to contact the Siemens Hotline for "expert intervention" (their words, not mine).
Online:
http://www.gigaset.com/en_US/support/contact.htmlWarranty Number: 1-866-247-8758 / Toll Free
Opening Hours: Sun. 6 pm - Fri. 6 pm continuously (EST)
