20 Most Recent
Kolpak Commercial Freezer Questions & Answers
Do the freezer latches have heaters ? my latch is icing up
There is a Mullion heater designed for that Kolpak that's actually installed inside the inside face on the door jamb. Kolpak may be willing to give you pointers but its best to let your refrigeration tech check it out. If its shorted you might be grabbing a door with 115 volts on it. Usually water from melted ice gets inside there and causes the heater to fail and short to ground. Hope this helps and good luck.
10/15/2014 8:54:22 AM •
Kolpak...
Answered
on Oct 15, 2014
Walk-in freezer / serial# 983170240P
Find a service mechanic you trust and get that door FIXED.
the ping pong ball is to allow the air pressure to equalize and the door to stay shut. Use only an approved door closer. Federal Law states that a walkin freezer door is to have an emergency escape means. That means what it says for a reason. So no one gets shut inside the freezer! After you fix the structure your problems will be a lot less. If you dont fix the structure then it will be a continual problem.
address other problems only after the "load" on the refrigeration equipment is taken care of.
1999 kolpak walkin freezer not staying cold
Is the compressor cycling on and off? Is there any oil around fittings at components? Gas is the last thing you put in a refrigeration system. You need to find the leak before you put any more gas in the system. Hope this helps good luck.
The door does not close on its own
You might want to check the bottom of the door and see if its dragging and make adjustments if it is. Also there are plastic cams at the door hinge pin area that are supposed to help the door close. They get worn and may need to be replaced. You can lift the door off of the hinge pins and inspect them. hope this helps and good luck.
Tappan TFC13M0AW1 Chest Freezer. What part should I replace?
Question edited to add maker! All questions need 'make model (what it is) as first three words.
That is an overheating fault. Replace the fluff with no fluff.
Make sure the condenser coils are free of dust and there is good airflow
Or
It is low on refrigerant gas and you need a service tech..
2/3/2024 5:25:13 AM •
Freezers
Answered
on Feb 03, 2024
