20 Most Recent
Lincoln Conveyor Oven - 1131-000-A Questions & Answers
Where can i find a manual for a samet stove?
look here
https://www.google.ru/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CB0QFjAA&url=http%3A%2F%2Ffruitfarm888.ru%2F&ei=eQarU8HeOuXnygOiloCwAg&usg=AFQjCNFYcGEHf3CR7e97fPRnLIBoLH06cg&sig2=Wvqu3y88ReaF03t5zDntqQ&bvm=bv.69620078,d.bGQ
How to reverse the conveyor
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Older Lincoln impinger keeps heating
t sounds like there may be an issue with the temperature control system in your Lincoln oven. Here are a few things you can check:
- Make sure the temperature probe is clean and inserted properly into the oven. If the probe is dirty or not inserted all the way, it may not be accurately reading the temperature.
- Check the thermostat for any signs of damage or wear. If the thermostat is faulty, it may not be able to regulate the oven temperature correctly.
- Look for any loose or damaged wiring. Loose or damaged wiring can cause the oven to overheat or not heat up at all.
- If the above checks don't identify the issue, it may be time to call a professional technician to diagnose and repair the oven. They will have the necessary tools and expertise to diagnose and fix any issues with the temperature control system.
The display can not be switched on the pizza Lincoln impreger
I make up to $90 an hour on-line from my home. My story is that I give up operating at walmart to paintings on-line and with a bit strive I with out problem supply in spherical $40h to $86h... someone turned into top to me by way of manner of sharing this hyperlink with me, so now i'm hoping i ought to help a person else accessible through sharing this hyperlink... strive it, you
Click For Full Detail.
Lincoln impinger 1450 natural gas oven will not Fire?
I have changed and checked fuses and compactor
Any ideas
This needs to be walked through with a multi-meter and manometer. First check incoming pressure in need to be 10" or above, under 14". if it goes to low flame we need to check the thermalcouple and ETC. If there is not a constant low flame, check pressures and voltage from the ignition module to the solenoid. Lincoln uses Honeywell modules that will just start putting out half the voltage and it isn't enough to open the dual valve. This is a hard question, I am assuming the blower motor is running. It can really be anything inside the oven.
