20 Most Recent
Technics SL-1210M3D Turntable Questions & Answers
Slow turntable
I'm not certain if you know this already, but the light that shines on the left side causes a strobe effect on the platter. One of series of 4 patterns will seem not to move when the turntable is at the right speed. To adjust this you need a record playing and then move the slider on the right till the pattern doesn't move. Which one not moving will depend on the speed selected and also the mains supply either 50 or 60HZ.
You will get some variation in the movement, but you shouldn't notice the difference in the speed. If this is set up right and you still think it's slow, then you might have to look either right under the turntable or inside it. There might be on the underside one or two holes that might be covered up. They might even be labelled 45 and 33. If you find them you will need a small screwdriver and place it inside. This will turn a small speed pre-set. You will have to adjust this till you think it's right, with slight movements, testing with a record.
If they are not present on the underside you will have to take off the bottom and look inside for a pre-set. Normally it will look like a 3 leg device with a screwdriver slot in the middle of it. Sometimes marked on the board "VR" with a number. Alternatively it will be on the other end of the motor. If you have trouble locating it follow the motor leads to the main board.
Some turntables have two speed pre-sets others only one.
12/31/2013 4:43:34 PM •
Technics...
Answered
on Dec 31, 2013
Very low volume from my technics sl6 even when
Hiya, first and foremost, is it plugged into the amps correct sockets? Turnatables have to in the PHONO (turntable) Any others , CD, AUX, MIC etc will not work. (sorry if that seems obvious, wasnt sure on the info provided)
If that is OK then check the stylus, probably requires a new stylus or/and cartridge.
Best of luck
11/11/2009 4:43:57 PM •
Technics...
Answered
on Nov 11, 2009
Technics RS-BX501 cassette deck door won't open
If you feel confident doing so, you could attempt to open the cassette deck and physically examine the gears to check for damage or debris that might be obstructing them.
But do remember that there are risks involved when opening electronic equipment, especially if you're not used with doing this kind of work. If you're not sure you can do this securely, it would be preferable to get assistance from a qualified audio equipment repair specialist.
