20 Most Recent
JVC HD52G887 52" Television Questions & Answers
Help with JVC HD52G887 red light blinking!!Please!!
The model indicated did have some real odd issues--some require a
computer to actually be connected to a plug inside the set to address
and or reset the processor in the set.
If the set functions except for this issue I would frankly just use it.
This is not unlike a issue I had in a older SUV---the check light would
come on and constantly go off and on every 5 minutes like a clock---when
looked up it meant something had triggered it but the issue did not
exist any longer--a reset of the computer stopped this annoying problem
and that light never came on again.
Kind of stupid but true.
Keeps turning off
Lamp is "possible" but model indicated did have a number of problems that require firmware updates to be performed.
I have a JVC 52in.
U did not specify how/when this problem started. If ur tv is stil new n stil covered by a warant, pliz col the supplier n return it, if not, then get a technician to look at it, thats a minor problem that can b fixed within a few moments. BUT u can also consult ur manufacturer's manual 4 hints n check ur settings tht u configured n c if u gt a different result.
The power and lamp light
The tv projection lamp life are over.Ur tv require a new projection lamp replacement.U used a remote,tries to turn the tv off?Might have dead battery in ur remote?Tries to push the manual button on the tv on and off see if that work.Than it is the remote.
My picture is small and i can't change the size
HI:
Check on your remote control for a aspect button or pic size button, or format button, if you are using a cable box for channels or satelite, look for these same buttons and go thru the different screens formats until you have the one you want. Or you may be in PIP mode (picture in Picture) if so look for a PIP button and push to turn off this mode
JVC HD52G887 52 in. HDTV Television lamp light and
you lamp may be cracked and need to be replaced or for some reason you may be having a surge, but my money is on the lamp. open it up and inspect the lamp for discoloration or cracks and buy a new one online and replace. This is really a cheap and easy fix
JVC 43" (109cm) HD Ready Plasma TV PD43N30A. Chunghop universal remote codes for JVC pd43n30a
Question edited for a lot more clarity, plus
Chunghop not chungCHOP :>D
JVC: 089, 161, 909
CHUNGHOP Universal Remote Control Codes
codesforuniversalremotes.com
https://codesforuniversalremotes.com > chunghop-univer...
Jul 25, 2019 -
CHUNGHOP Universal Remote Control Codes ; Aiwa: 009, 057, 058 ; Samsung: 618, 619, 620, 621 ; Philips: 013, 023, 024 ; Hisense: 676, 677, 707, 898
My JVC TV has an onscreen remote that doesn't let us use the actual remote what do I do to gat it out?
Hello! If your JVC TV is displaying an onscreen remote and you're unable to use the actual remote, you can try the following steps to resolve the issue:
- Power cycle the TV: Turn off the TV and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. This can often reset any temporary issues and restore the functionality of the actual remote.
- Replace the remote batteries: Check the batteries in your remote control and make sure they have enough power. If the batteries are low, replace them with fresh ones and try using the remote again.
- Check the remote control sensor: Ensure that there are no obstructions between the remote control and the TV's remote control sensor. Clean the remote control sensor on the TV with a soft, lint-free cloth to remove any dust or debris that may be interfering with the signal reception.
- Reset the TV to factory settings: If the issue persists, you can try resetting the TV to its factory settings. Keep in mind that this will erase any personalized settings and restore the TV to its original configuration. Refer to the user manual or the manufacturer's website for instructions on how to perform a factory reset on your specific JVC TV model.
- Contact JVC customer support: If none of the above steps resolve the issue, it's recommended to reach out to JVC customer support for further assistance. They will have access to more specific troubleshooting steps and can guide you through the process of resolving the issue with the onscreen remote.
Keep in mind that the exact steps and options may vary depending on your specific JVC TV model. Refer to the user manual or contact JVC customer support for model-specific guidance.
