20 Most Recent Sharp LC-32DA5U 32 in. HDTV-Ready LCD Television Questions & Answers
2answers
Hooked up to antenna did channel scan in air mode not getting any channels. Hooked up a Vizio tv to same antenna line and got all the locals. Maybe something wrong with the Sharp?
Make sure that Sharpe is set to over the air/antenna and not cable. There are more than one scan modes. http://files.sharpusa.com/Downloads/ForHome/HomeEntertainment/LCDTVs/Manuals/tel_man_LC42_46_52D65U.pdf See page 14 in the link. It is easy to mis-configure the setup to not receive the over the air digital channels. The input must be set to digital and air in setup. The VHF are no longer available. Hope this helps?
4/9/2016 1:57:44 PM • Sharp LC-32DA5U... • Answered on Apr 09, 2016
I'm looking for the remote code for this tv so I
If you are using Direct TV, the codes are available at the direct tv website....
Directtv has a link on the TV using the menu for programming the remote control.
And if not directv, look up the model of your current remote, and see what the code for Sharp is ..
good luck and don't forget to vote!!!
10/11/2010 12:39:54 AM • Sharp LC-32DA5U... • Answered on Oct 11, 2010
No Picture
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try plugging in the TV through the USB on its panel to a computer or USB charger, and it may work. However, this is only a temporary solution.
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
4. A circuit board may crack about some of the larger components mounted on it. You can inspect the PCB's for fractures, and then repair them. It may also be poor soldering that has failed. I would be checking for these things first.
5. If you want to go in for a long term solution, you can easily replace the whole power board or just change the faulty capacitors. You will have to open the back panel and take a look. You can make out which are faulty, because their caps will be swollen on top. Here's a sample pic (not same model):
Check the specifications of the faulty capacitors, and get the replacements from your local electronics shop. If you are comfortable with this, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors. Once that is done, solder in the new capacitors carefully. If are unsure how to do this, try to get a friend who knows how to do this kinda stuff do it for you, or get a qualified technician. Warning: If you do not have a background in electronics repair, or are inexperienced, get a qualified technician to do it for you.
REMEMBER there are very dangerous voltages inside a TV that can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECT THE POWER BEFORE YOU DO ANYTHING.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
10/26/2008 3:54:56 PM • Sharp LC-32DA5U... • Answered on Oct 26, 2008
How do get full screen on LC-15S2u
Menu on remote and make sure you have it on wide screen or 16 to 9
1/17/2019 10:35:18 PM • Sharp LC... • Answered on Jan 17, 2019
Why isnt roku 3 working through my LC-32DV24U roku 1 worked fine
Hello If your Roku 3 player is not connecting to WiFi, it is possible that the WiFi signal from the router is out of range. In order to strengthen the signal, move the router and Roku 3 so that there are fewer objects and walls between them. For any help or support just visit us: www Roku Com Link
5/26/2018 8:22:34 AM • Sharp LC... • Answered on May 26, 2018
When I connect my wd box to my tv it blacks out every 10 secs very annoying when watching a movie. This doesn't happen when we watch a dvd. When we watch regular cable we see a blue box appears on t
When you say WD box, do you mean a Western Digital Hard Disk Drive? If so, get a Solid State Drive (SSD), and connect it via USB3. The HDD or the USB connection is not fast enough to keep up with the required speed of the video. If you mean something else, please add details.
12/5/2017 9:28:46 PM • Sharp LC... • Answered on Dec 05, 2017
I have a Sharp LCD TV Model # LC 32SB220U. When you turn the power on, within a minute or two, it clicks off. I have tried everything in the instructions to troubleshoot the problem. I also reset to f
Check the high voltage circuit on the board that has the 120 volts input. The high voltage should be close to 400 volts - nothing less than 390 volts. The capacitor is failing to hold the voltage and needs to be replaced.
10/29/2017 1:23:31 AM • Sharp LC... • Answered on Oct 29, 2017
I have an LC-32D33X sharp tv... it just turned off on me :( and now the OPC and the power lights on the tv are flashing SOS style :(
un plug tv and try to force on by pressing vol_ and input button from tv then plug back in see if tv comes on .
12/16/2016 9:30:47 AM • Sharp LC... • Answered on Dec 16, 2016
How do I find out the year my Sharp Aquos TV was manufactured?
Look for it at its bottom side [stand]
9/26/2016 6:46:48 AM • Sharp LC... • Answered on Sep 26, 2016
Instruction manual for Sharp Roku tv LC-32LB481C
Hi, Here you can get solution of your question/problem. https://support.roku.com/hc/en-ca/articles/209403268-Roku-TV-Introduction
9/17/2016 4:39:52 PM • Sharp LC... • Answered on Sep 17, 2016
Sharp LC-32DA5U 32 in. HDTV-Ready LCD Television Logo
9 questions posted
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
LC Sharp
  • LC Sharp
Most Popular Question
looking remote code tv
  • Televison & Video
