20 Most Recent Sharp LC37SB24U 37 in. LCD TV Questions & Answers
Two separate remote controls will not turn TV
Are you you using the remote that came with your television?
7/14/2017 9:36:03 PM • Sharp LC37SB24U... • Answered on Jul 14, 2017
Remote does not work
If you have replaced the batteries and not have put them in backwards, look at the remote thru your cell phone camera. Press any button on the remote. If it is working at all you'll see the led flashing . If you see this and it's working, then the infra red receiver in the TV isn't working.
9/12/2016 5:36:47 AM • Sharp LC37SB24U... • Answered on Sep 12, 2016
Tv has no picture. When turned on, the OPC and power blinks. Can you tell me what the problem is?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience.
8/1/2014 9:18:13 AM • Sharp LC37SB24U... • Answered on Aug 01, 2014
2answers
Factory reset with universal remote
Are you talking about secret number or did you break the button that brings up the menu? It shouldn't be possible to lock out direct button entry. To clear your secret number: http://s3.amazonaws.com/szmanuals/1673990ad2c5041f6d45ee373745c145 Page 30.
7/21/2014 4:40:53 AM • Sharp LC37SB24U... • Answered on Jul 21, 2014
Power, I can hear the relay keep clicking every 2 second. will not power up.Any idea as to what can cause that?
Sounds like main board fault. Contact the authorized service center. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter". http://electronicshelponline.blogspot.com/
6/17/2014 3:46:26 PM • Sharp LC37SB24U... • Answered on Jun 17, 2014
No picture and sounds
pa check po na smps +12v at -12v
4/21/2014 10:06:52 AM • Sharp LC37SB24U... • Answered on Apr 21, 2014
TV will not stay on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given.
3/11/2014 2:50:17 PM • Sharp LC37SB24U... • Answered on Mar 11, 2014
I am currently working on a Sharp Lc37sb24u. I was
Did you check the service manual troubleshooting guide yet. You can try disconnecting the power to the inverter board and see if it will stay on and have sound.
Service manuals:
http://elektrotanya.com/?q=showresult&what=Sharp%20LC37SB24U&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
2/20/2014 5:57:14 AM • Sharp LC37SB24U... • Answered on Feb 20, 2014
Picture but no sound
First start with the simple things, make sure the mute feature isn't turned on. Also check the menu, some sets give you the option to turn off the internal audio. If these suggestions aren't the case, your set may need servicing.
11/11/2013 6:31:11 PM • Sharp LC37SB24U... • Answered on Nov 11, 2013
We have no audio
Check the speaker/s first. If found OK, check and replace damaged component/s at its audio out put section circuit. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic /Timeslide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
11/8/2013 3:02:23 PM • Sharp LC37SB24U... • Answered on Nov 08, 2013
I have a panasonic plasma tc-p50x1 that had the red led blink 9 times
9 times blinks denotes Panel Config. SOS.If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/. Standby LED blinking codes and fault locating procedure to Panasonic Plasma Displays are described in detail.
5/9/2013 2:25:42 PM • Sharp LC37SB24U... • Answered on May 09, 2013
The picture is breaking up
Check all inputs sire harshness for firm. If there is any loose connections to these, the fault you reports here can occur.
2/5/2013 9:01:05 AM • Sharp LC37SB24U... • Answered on Feb 05, 2013
Won't turn on and no lights on when plugged in
Check and replace the back light inverter board.
9/29/2012 5:13:20 PM • Sharp LC37SB24U... • Answered on Sep 29, 2012
My tv turns on then off quickly
I see so many here with no sound/nopicture issues:ISSUES: 1. IF sound main fuse/s are good.2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.4. Be safe and if you do not know what you are doing don't open the set.Answers to issues:1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.4_26_2012_1_34_44_pm.jpg
4/26/2012 1:34:50 PM • Sharp LC37SB24U... • Answered on Apr 26, 2012
2answers
Green power light blinks, tv won't turn on more
Tv is going into fault protection. Bad Caps on the PSB-Power supply board
Best regards and Semper Fi
11/25/2011 3:12:39 AM • Sharp LC37SB24U... • Answered on Nov 25, 2011
My LC-37SH20U was working fine. Then, when I gor
This is a fault solution which can be checked and corrected by you assuming that there is no component failure. There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance.
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing.
Check for tips to look into the SMPS unit with some of my tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Thank you for using Fixya.
8/23/2011 10:48:07 AM • Sharp LC37SB24U... • Answered on Aug 23, 2011
Sharp LC37SB24U 37 in. LCD TV Logo
58 questions posted
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
LC Sharp
  • LC Sharp
Most Popular Question
tv no picture when turned opc power
  • Televison & Video
