20 Most Recent Oster 6803 14 Speed Blender Questions & Answers
3answers
Replacing the part that connects the motor to the blades on an Oster blender
I don't know if this will help or if this is what you are looking for. But today I was searching the web for the bottom piece that fits on the jar and saw this website has a lot of replacement parts for Oster blenders. Hope this is what you're looking for.
Good Luck
http://www.goodmans.net/get_item_os-070_square-drive-pin-for-oster-osterizer-blenders-shor.htm
7/19/2012 6:42:24 AM • Oster 6803 14... • Answered on Jul 19, 2012
Oster blender pro 1200 stops prematurely and 2 present lights blink 3 times
It sounds like overheating or a control board failure. Contact the maker for a warranty claim https://www.google.com/search?q=Sunbeam+sfs001+manual ..
12/24/2022 9:07:42 PM • Oster Blenders • Answered on Dec 24, 2022
The fuse went out on my Oster Dual Action Blender BLSTRM-DZG-BG0. I've purchased multiple fuses but can't seem to find the correct size. Has anyone successfully replaced one of these fuses? If so, where did you find it? Thanks so much!
Same thing happen to my blinder, it uses 5A fuse 250V. But even if you replaced the fuse it still blow up... some other issue related that make the fuse blow
7/8/2021 11:34:50 PM • Oster Blenders • Answered on Jul 08, 2021
I do not know how to remove the coupling pin from my OsterĀ® 700 Watt 8 Speed Stand Blender. Can you please help me?
check the operator manual - and see the parts breakdown picture. the sequence of parts to remove to replace it would be evident from the pictures.
12/21/2018 11:44:50 AM • Oster Blenders • Answered on Dec 21, 2018
Where can I get a replacement fuse for my Oster precise blend 12?
Hello, Frances - Your question landed in the Fixya.com category of Furniture. I re-categorized your question to the Oster Blenders category. I found the following information regarding Oster blender built in fuses: (Quote) The built in fuse protection has kicked in. To turn the blender back on, first turn the control knob to "Off" and unplug the unit from the wall. Then remove the jar from the base and free the blade of any obstructions. Next, press the external resettable fuse button on the bottom of the base. Wait 30-45 minutes for the unit to cool. (End quote) Source: https://www.oster.com/service-and-support/product-support/product-faqs/blenders/oster-versa/blenders-oster-versa-faq.html?faq=blenders-oster-versa-faq-Q-A-4 Question: My blender shut off during use. What happened? If you try that possible solution and the blender still does not start, then . . .this is the link to the Oster Contact Us page: https://www.oster.com/customerservicecontact?cid=contactus At the very bottom of the page you will find toll free Customer Service phone numbers. Or . . . Fill in the form there, asking about the availability of a replacement fuse for your model of Oster blender, so that you can send an email message. Best wishes.
9/26/2018 6:05:08 PM • Oster Blenders • Answered on Sep 26, 2018
Where can i buy oster 4172 rubber rings
Sorry we do not have parts locators services here.
3/30/2018 11:06:02 PM • Oster Blenders • Answered on Mar 30, 2018
We have an OLD Oster blender model 442. It is over 50 years old. Problem is one of the seals is no longer usable. Anybody have any ideas on obtaining a seals for this antique.
there are compaies around that sell seals , bearings and "O" rings see if you have such an operation in your state and contact them with the measurements of the seal
3/14/2018 4:11:26 AM • Oster Blenders • Answered on Mar 14, 2018
No power light on the Oster 6700
Get it touch with a local Oster repair guy. Likely he can solve your problem, over the phone. You may need to take it to them.
3/4/2018 9:06:57 AM • Oster Blenders • Answered on Mar 04, 2018
Oster 2 speed blender started smoking. Now it won't work.
I do believe the motor must have burned out.
5/12/2017 5:33:15 PM • Oster Blenders • Answered on May 12, 2017
0answers
0answers
Oster blender
Be the first to answer 9/4/2016 12:56:21 PM • Oster Blenders • Posted on Sep 04, 2016Be the first to answer
5answers
I have an oster My Blend with the blade stuck in the base. Any ideas on how to get it out? Model BLSTPB-WBL
None of these people understand your question. The blade assembly is stuck in the blender base and will not untwist out of the base. The sport bottle untwists off the blade assembly leaving it in the blender base. I've tried using pliers on mine after taking it apart. Something is binding it from untwisting. What is the trick to untwist the blade assembly off the blender base?
6/17/2016 10:11:35 PM • Oster Blenders • Answered on Jun 17, 2016
0answers
Oster 6803 14 Speed Blender Logo
3 questions posted
Top Oster Blenders Experts
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Joaquin A Barahona ...
Are you an Oster Blender Expert? Answer questions, earn points and help others
View Most Popular
Oster Blenders
  • Oster Blenders
Most Popular Question
replacing part connects motor blades
  • Blenders
