20 Most Recent
Dell E772p Monitor Questions & Answers
Normal RGB values
Dear Anonymous,
If you could give more info on your question, it would help us a lot.
- info of your monitor, - if you need to configure the setting on the monitor itself, - if you need to configure from windows or other platform, - if you need to configure with "Intel HD Graphics Control Panel. But don't worry I can give you a common configuration as I did to setup when using other computer for graphic designing.
1. go to this link
http://www.pawprint.net/designresources/monitorcalibration.php and follow the instruction.
2. If you have a color printer or a photo print of a digital photograph and a digital file (your photo from a digital camera with distinctive colors). Open the digital file of the photo and match the colors with the print of the photograph. This sounds very primitive but this is the most logical way and nearest way to correct match what you see and what you get.
Hope this helps. But let me know if you need more information.
Good luck
My Dell Monitor E772P Control
The menu should tell you to press 1 (or 2) to get rid of it. The (1) and (2) refer to the first two buttons on the bottom right side of the monitor.
I have a deel monitor
is hardware problem, the power supply is malfuntion, needs to be checked by a tech.
Monitor no display
I would suggest retouching the solder joints on all components in the area of the affected components. Sometimes solder joints weaken and put additional stress on other parts. This is a common problem in many Dell and BenQ LCD monitors.
I want to know about some adventures video games?
Check out Big Fish Games. It is a subscription service but they have all types of games including adventure and hidden object. You can also tryp Pogo since they have both a fee and subscription service. Last, but not least, you can try one of your local computer stores or the electronics section of "big box" stores like Target, Walmart, Kmart, etc.
