20 Most Recent
i-rocks External Hard Drive Enclosure - Silver Aluminum, USB 2.0, IR-9300 3.5in Drive Case Questions & Answers
How do I delete all
Usually hard drive disks are erasable so long as was an an empty space. However, the type of setting chosen during data encription causes the situation of erasability. For example, using an external harddrive disk as back up media storage media has specific requirements. The computer provides an integral means of least being compromised where data permanent encription may have been the options available during backup copying. The compoter provides the procedures of recording data into any connected external devices. Once the external device is reconnected to the computer, the options of requesting the user to either erase what has already been copied becomes one of the several displayable promps. Also, backup disks usually on connection to the computer assumes a necessity to restore to functioning mode. However, a least malfunctioning computer would simply display prompts asking the computer user to perform the most recent backup, or disregard because of least disfunction recognised from the system. Attempting is erase what has already been recorded becomes appropiate whenever the computer recognises any curroption of the files. A prompt is display asking to fix errors soon after connection. The computer user simple chooses to restore to default functionality the external hardrive. Amongs the options usually provided of the program prompt are format, delete, restore, or backup computer files once connection is recognised. keep in mind that, an external hard disk may be default rrecordable proving no options of erasing. Refer to the hard disk drive user guide as reference to achieve the process. Also, the user guide would have specified if the device is capable of alternations or not.
I have an i-rocks 3.5 usb/firewire combo external
The clicking isn't a good sign; it means the drive is being repeatedly told to start rotating but it either can't start or come up to speed.
There is a problem called 'stiction' meaning that the head(s) are somewhat 'glued' to a disk surface.
Haven't heard of this problem in recent years but it still may be possible and not as likely with the extreme shrinkage of head size..
BTW, the actual drive probably has a different name and model number but would have to be removed to see the label.
My irocks enclosure only came with 98 drivers
Xp does not need them but check the information below before you panic.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Dropped hard drive
You can try using Ghost to back the data up. It sounds to me like a head crash.
I-rocks ir-9200
when u want to use them them in an encrosure u first have 2 remove the metal bars that attach the hard drive to the laptop once the bars r removed it iz ready to fit in the encrosure
Numlock does not work, numbers ok on main keys
your keyboard may have gone bad, the simplest troubleshooting start for keyboard problems is to have someone lend you a working keyboard and see if you can recreate or solve the problem. make sure you turn off your computer before replacing the keyboard.
12/31/2009 5:04:28 AM •
i-rocks...
Answered
on Dec 31, 2009
How to Install YouTube DL.py to Download YouTube Videos to my PC?
Actually, you just need the help of a YouTube Downloader. If you still need help, why not try this YouTube/Video Downloader?
Leawo YouTube Downloader acts far more than a single online video downloader to download YouTube videos and other online videos from various video sharing sites like Facebook, Dailymotion, AOL, iFilm, Myspace, Dailymotion, etc. Besides the ability to download online flash videos, this FLV downloader could also acts as video download accelerator to speed up online video downloading, video accelerator to speed up video buffering for smooth playback, video player to play back videos, and IE browser to browse online videos for free downloading. It could extract audios out of online videos, like converting YouTube video to MP3.
Hope it can be another choice for you or other users. :)
Watch online videos offline freely with Leawo YouTube Downloader
What is digital marketing?
Digital marketing, or “online marketing,” is a form of advertising that uses the internet and digital technologies to connect with customers. Digital marketing seeks to accomplish the same thing as traditional marketing except by leveraging computers, smartphones, and other digital devices rather than traditional media, such as print, radio, or television.
