Question about i-rocks External Hard Drive Enclosure - Silver Aluminum, USB 2.0, IR-9300 3.5in Drive Case
How do I delete all the info backed up on my irocks external hard drive?
Posted by rhenderso918 on
Anonymous
    Novelist:
  • 118 Answers
Usually hard drive disks are erasable so long as was an an empty space. However, the type of setting chosen during data encription causes the situation of erasability. For example, using an external harddrive disk as back up media storage media has specific requirements. The computer provides an integral means of least being compromised where data permanent encription may have been the options available during backup copying. The compoter provides the procedures of recording data into any connected external devices. Once the external device is reconnected to the computer, the options of requesting the user to either erase what has already been copied becomes one of the several displayable promps. Also, backup disks usually on connection to the computer assumes a necessity to restore to functioning mode. However, a least malfunctioning computer would simply display prompts asking the computer user to perform the most recent backup, or disregard because of least disfunction recognised from the system. Attempting is erase what has already been recorded becomes appropiate whenever the computer recognises any curroption of the files. A prompt is display asking to fix errors soon after connection. The computer user simple chooses to restore to default functionality the external hardrive. Amongs the options usually provided of the program prompt are format, delete, restore, or backup computer files once connection is recognised. keep in mind that, an external hard disk may be default rrecordable proving no options of erasing. Refer to the hard disk drive user guide as reference to achieve the process. Also, the user guide would have specified if the device is capable of alternations or not.
Posted on Jan 14, 2011
Plugged in external hard drive and does not appear on desktop
Go to Administrative Tools>Computer Management>Disk Managemant and see if the drive appears there. If it does, you may need to delete the partitions on the drive and create new ones. If this doesn't work, you may need to contact the manufacturer for a possible replacement.
Mar 14, 2014 | SimpleTech 250GB USB2.0 7200 RPM External...
I have deleted some files on a Western Digital My Book external HD. It is a LAN drive. Do not know how to undelete these files again.
If you are using windows, files are transferred to the Recycle Bin before permanent deletion unless they are too large, in which case they are permanently deleted.
After permanent deletion, recovery is not possible without specialist reconstruction software and even then may be very difficult or impossible, especially if the drive has been defragmented or formatted
Mar 26, 2011 | Western Digital 500GB My Book World...
I have a 453 GB Lap Top, 500GB Hitachi will not back, says no more space, I was told to delete all info on 500GB and do new back up, How do I delete info from 500GB?
Open up Windows Explorer (the file manager).
Right-click on the 500GB drive (drive D: or whatever it is) then click Format.
If it says the drive is in use, make sure you close all other Windows Explorer and Command Prompt windows and try again (worst case, reboot then try again).
Jan 14, 2011 | Hitachi 500GB External USB 2.0 Hard Drive
I need general info on using an external hard drive. My computer is full and I'm unsure if I should replace the computer or start moving thing to the external hard drive. Also, I keep getting a message...
The drive will be assigned a letter. Find it in my computer. You can right click on any file and select send to and send it to the external drive. Basically you now have a backup of that file. Now you can delete the origional off the main hard drive and just read the file from the external drive. As far as the icons right click and select find target. That will show you were the file is and you can delete it.
Nov 22, 2009 | Western Digital Elements powered by WD 320...
When I move my info to my external hd and I delete it from my comp. It also deletes it from my external. Help
first clean your operating system with antyvirus
and than clean also your external hd
first copy and paste it and after cofirmation delete it.
Aug 29, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
Delete info from an external hard drive?
run diskmgmt.msc delete. then create then format .. also theres a tool called Wipedisk from www.thefreecountry.com/security/securedelete.shtml
Jul 21, 2008 | Maxtor Hard Drive
Dropped hard drive
You can try using Ghost to back the data up. It sounds to me like a head crash.
Jun 14, 2008 | i-rocks External Hard Drive Enclosure -...
Open Questions:
i-rocks External Hard Drive Enclosure - Silver Aluminum, USB 2.0, IR-9300 3.5in Drive Case Logo
Top i-rocks Computers & Internet Experts
k24674
Are you an i-rocks Computer and Internet Expert? Answer questions, earn points and help others
