20 Most Recent
Proview PL 765 (Silver) 17 in. Flat Panel LCD Monitor Questions & Answers
Need a power adapter
you can try this link they sell inexpensive refurbished items
http://www.tamayatech.com
also you can try a place that has hard to find or older computer equiptment
http://www.codemicro.com
Proview monitor, model 900P, product PL913s. I have it hooked up to computer and to power source, but can't get monitor to turn on. Something more needed beside the "power" button on right?
- Check the power cable: Make sure the power cable is properly connected to the monitor and to the power source.
- Check the video cable: Make sure the video cable is properly connected to the computer and to the monitor.
- Check the computer settings: Make sure the computer is set to the correct display settings for the monitor. You can typically do this by right-clicking on the desktop and selecting "Display settings."
- Check the power source: Make sure the power source is working and that there is no problem with the outlet or power cord.
- Check the power button: Make sure the power button on the right side of the monitor is not stuck and is functioning properly.
- Try a different cable or computer: If possible, try connecting the monitor to a different computer or cable to see if the issue is with the computer or cable.
If none of these steps resolve the issue, it may be a problem with the monitor itself
2/13/2023 3:11:21 AM •
Proview...
Answered
on Feb 13, 2023
Model 2200W Proview LCD Monitor - How do I connect it to HP Laptop?
Since you don't provide the laptop model, I assume your PC has at least a 15 Pin VGA connector. You will need a 15 pin male VGA to 15 pin male VGA cable, just plug it at the laptop and the monitor, that should do. If your laptop has also an HDMI or DVI or Display Port, you will need a proper cable or adapter.
7/30/2014 4:41:53 PM •
Proview...
Answered
on Jul 30, 2014
Using tv as computer monitor
Have the ps2 cable pluged into your tv from your computer. On the remote press the input button then slide through the screen until you get to the pc setting hit enter on the remote then follow the screen on the computer and tv.
Terry
1/26/2014 1:31:05 AM •
Proview...
Answered
on Jan 26, 2014
